-   I turn on 8800 and then it turns off automatically, this sometomes happens several times. I have to work the camera just so it will stay on. Once it is on it will remain on until at some point it shuts down automatically and the here we go again. Any clues/suggestions- thanks Mike H-   nysdop
Make sure to use good NiMH batteries. Another possiblity is a problem with the card. Borrow a card and see if it has any effect. check to see that the pins in the card slot are all aligned, none out of place. check that the card door and the battery door close firmly, with some pressure. The camera can shut down when it has a problem detecting that the doors are closed.
When it does turn on, play with the zoom without taking pictures, zoom in and out, if during zoom the camera shuts down then you might have a lens problem, something is malfunctioning in the lens mechanism and the camera shuts down to prevent damage.
Make sure the battery contacts are clean also the camera's battery contacts can get grubby too. You cold be suffering from an intermittent connection. Worth a try.
I have a nikon coolpix 8800 and it will not turn on. I have purched a new battery and a new charger....
(More)
I have a nikon coolpix 8800 and it will not turn on. I have purched a new battery and a new charger. Still doesn't come on. Can you help. Thank you Barb
camera dies with lens only half retracted. battery charged, but immediately looses it's charge when...
(More)
camera dies with lens only half retracted. battery charged, but immediately looses it's charge when the attempt is made to turn the camera on. New battery - same problem. Help, Ginny
