Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius flashing pre wash light and nothing happens for ages not taking powder only since main door seal was changed
  • Anonymous Mar 24, 2014
    How to change door seal on Aquarius wmf720 washing machine
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Posted on Sep 13, 2008
Door lock flashes doesnt work or start up
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
Jan 20, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf321 when turn on all red light fleshing Problem nothing happenes.
half way through the cycle all the lights start flashing then it makes a loud noise when spinning
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My machine is a hotpoint aquarius and after a wash the clothes come out of the machine smelley. I also have a grime on the rubber seal around the door
A couple of possibilities her:
  1. Washer not rinsing and draining properly
  2. You are doing too many low temperature washes
Solution to 1 is to check and clean pump filter.
Solution to 2 is, do more high temp washes, even if you do not put clothes in, do a 90 degree wash with powder in, this will help keep the smell from reocurring, and help keep the seal clean.
Please rate my solution.
Thanks.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
345 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
