Question about Sunbeam Heating & Cooling
Electric blanket flashing E2 on control panel.I have unplugged it and plugged it in again LCD screen still flashes.
  • shaza
    shaza Oct 28, 2013
    sunbeam told me that E2 meant my side of bed was defective and won't work,has to be replaced and if not in warranty, that means whole new blanket :(. Superking are not cheap!
  • John horsfall
    John horsfall Sep 19, 2017
    You are so right did they come back as to what the error was ?
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
  • 1796 Answers
SOURCE: My queen size electric blanket...
Hi!!
Here is some of the frecuent questions regarding "F" flashing on the Temp. Controls. Clicking on the following link will take you to the Owners Manual Page for Sunbeam Electric Blankets.
If you need additional info. post a comment. Good Luck!
http://www.sunbeam.com/manuals/SunbeamBedding/7Ctrl_Man.pdf
Q What does “FF” mean on my Electronic Digital Control?
A
The digital controls are designed to notify you in the event that a problem has been
discovered by flashing “FF” on the display. Follow instructions on the flag tag to reset
control. First, check the blanket/mattress pad for visual damage. If no visual damage is
found, unplug the system from wall outlet. Check that the control is well
connected to the module. Plug the power cord into the wall outlet. Set the
control to “On.” If the system still does not operate after 2 or 3 times
trying to reset, disconnect the power cord and contact Sunbeam Consumer
Care.
Q What does a flashing light mean on my EasySet™, SlimStyle™ AO or
SlimStyle™ control ?
A
These controls are designed to notify you in the event that a problem has
been discovered by flashing the light on the control. Follow instructions on
the flag tag to reset control. First, check the warming product for visual damage. If no
visual damage is found, unplug the system from wall outlet. Check that the control is well
connected to the module. Plug the power cord into the wall outlet and turn the control On.
If the product still does not operate after 2 or 3 times trying to reset, disconnect the power
cord and contact Sunbeam Consumer Care.
Posted on Sep 03, 2010
SOURCE: sunbeam electric blanket flashing ff
Ok folks. I fixed it. I unplugged and then waited and replugged and started at high or 9 and then it went to FF in 60minutes or a couple of minutes. I scratched my head and tried this fix--instead of starting again at 9 or H I started at level 7. That did it. FF most probably indicates excess current, and the H or 9 probably is too high to set. So unplug -repluf-turn on and dial 7 or lower. It should fix it. Or buy a new one.
Posted on Nov 21, 2010
hvac1960
  • 2133 Answers
SOURCE: the display panel on the
E-2 means indoor coil sensor not effective. Better clean with salt paper or replace it. Hope you wouldn't had cooling. Am I right? Thanks.
Posted on Dec 11, 2010
hvac1960
  • 2133 Answers
SOURCE: Electric blanket won't stop flashing
FF- loose contacts wiring. check all fuses and also wiring to your unit.
Posted on Dec 26, 2010
What does the error sign E2 mean on a biltmore electric blanket. Mine stays on and does not heat
From what you said I take it that you have dual controls? Or do you have a single control for both sides? Anyway, the Sunbeam people are not very helpful. First - Unplug your blanket from the wall outlet. 2. Look at your plug-in into your blanket. Make sure you have not reversed the plug. 3. Look for recessed pins. If you find one recessed, use a pair of needle-nose pliers and carefully pull out the recessed pin until it is even in length with the other pins. Reinsert your plug then plug the unit back in. If the error still occurs, you probably have a broken heater wire inside the blanket. I know the Biltmore blankets are spendy.
Nov 29, 2017 | Heating & Cooling
Blanket flashes f2 when plugged in. I have plugged control into blanket and electrical outlet. It still flashes f2
Sometimes you have to unplug and re-plug the blanket multiple times. The control might reset itself. If that does not solve the problem, more than likely, you have a break in the heating element wire, or a control board issue. If you are proficient with an electrical tester, you can check continuity of the wire at the plug in. Depending on your model, you can also take a look inside the control for any broken solder connections, or loose wires. Otherwise, I'm afraid there is not much else to do.
Oct 30, 2017 | Home
The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Winter's tale electric heating blanket flashing "F"
I\'m having the same problem as Jenn. Tried unplugging it and left it for a day. Both sides are now not working. How can I get it to work again? Husband is having a hissy. Please just tell me what to do. or tell me how to download the manual. Haven\'t had this for very long 2 months. if any help.Mary Ellen I did love this when it did work.
Nov 19, 2013 | Winter's Tale Microplush Electric Blanket...
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
My dual control sunbeam electric blanket flashes on one side
Return this product as it is a fire hazard.
please mark this as a fixya! thanks
Feb 22, 2009 | Sunbeam 4237 / 4238 Iron with Auto...
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Sep 20, 2008 | Heating & Cooling
Heating & Cooling Logo
2,954 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
