SOURCE: black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
SOURCE: screen is black and the green light is flashing
Monitor is definitely bad then, could be bad capacitors on the power board but getting it repaired at a shop would cost more then just buying a brand new monitor.
SOURCE: black screen green lite on/flash right green lite off
The problem on your monitor is a bad power supply. We you can solder you should be able to repair it. If you check our site at :
www.ccl-la.com/badcaps.htm We have a monitor repair section with dis-assembly guides and repair procedures. I will post a Hanns-g guide tonight. This will show how to open and repair the monitor. We also have a repair parts kit available. If you don't want to do the repair yourself then we can do it for you, just email me if you have questions or wan tus to do the repair for ou.
I hope this helps.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Optiquest q20wb LCD has black screen & green power light flashing
Hi Rickyknows2,
If you are not hearing any beep I assume you are having problem with your video so, please ...
- open your PC and check whether your video card is well placed (sometimes it looks fine but you never know) remove it and put it back.
- If you used to remove often the cable from the PC, it might be that the pins from the monitor cable are even broke... please check.
- try to find another video card and replace it just to make sure its the video ...
- last... reset the bios (but I doubt that this is your problem)
chsers ..
