Question about RCA RS2650 Shelf System
Power Problem Well after a certain amount of time the unit wont turn back on from standby and the clock is frozen also. the only way i can get it to turn on is to unplug it and then plug it back in. its not even a year old and it was a gift for my mom cause i blew out her stereo (woops). Shes really dissapointed and i was just hopin to find out an easy way to fix it.
    President:
  • 3,130 Answers
Its not a typical repair that a do it yourselfer can do unless youve had troubleshooting experience on microprocessors. Your problem could be the 5 volt power supply is not filtered clean when it warms up or the reset voltage falls too low for the micro. good luck
Posted on May 19, 2006
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
    Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
    Mar 20, 2011 | Memorex MVD2042 DVD Player
    I would like to set the clock on my sanyo 32
    The easiest way is some sort of automation system like Crestron or RTI with an astronomical clock and IR capabilities.
    You could easily add a timer to the outlet but that will only take the TV from all off to standby. To turn it on you have to send the IR command for power. Also, I doubt the Sanyo has discrete codes for power which will make this impossible to make reliable because if the TV is on at the time you have the automatic power ON it will turn the TV off.
    If you really have to do this, here are the parts:
    RTI XP8 RTI VS1 Niles MF1 Programming software and a programmer
    Nov 24, 2009 | Sanyo DP32648 32 in. LCD TV
    LG DVD Recorder- Clock settings Model RH277H
    The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
    Dec 28, 2008 | LG RH299 DVD Recorder/VCR
    Kenwood KDC-138 Standby Question
    Standby mode does not completely power down the unit it jsut does not draw as much power as when the unit is on. Also, depending on the unit, it might start back up faster in standby then from power off. You can select to have certain things displayed while in standby mode. Here is what can be selected for this unit:
    Standby: displays CD loaded indicator, "STBY" indicator, and clock (when selected)
    Hope this was helpful.
    Oct 29, 2008 | Kenwood KDC-138 FM / AM Receiver
    Clock reset and cant find satellite
    I have had the same problem. I just notice the power switch on the bottom of the unit. I believe if this one is used it will not lose power. The other power button is probably for a standby mode.
    Oct 21, 2008 | Sanyo NVM-4050 GPS Receiver
    Sony 32XBR400 Wont Power On
    I do not believe the set is too far gone. The standby light blinks codes up to 7. If the standby light blinks more than 7 times it usually means that there is a short on the clock or data line. There are several small zener diodes connected to the clock and data lines in a couple of different places on the main board. Many times I have seen one of the zener diodes become very leaky, usually along the back of the board, loading down the clock or data line which produces the symptoms you are seeing. If you have no experience locating shorted zener diodes and unsoldering and soldering small parts, allow a qualified tech to service the set for you.
    Aug 27, 2007 | Sony KV-36XBR400 36" TV
    DVD player stuck in standby mode
    Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
    May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
    RCA RS2650 Shelf System Logo
    100 people viewed this question
    Top RCA Audio Players & Recorders Experts
    Gyula Lacz
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
