Removal of washing machine soap dispenser - Indesit
Hi
Could you tell me how to remove the soap dispenser on my Indesit WIXL105, so that I can clean it.
Thanks
Sue
  • Anonymous Mar 23, 2014
    water remaining in draw
  • 958 Answers
Hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
    Genius:
  • 1,239 Answers
Hi
When you wash very linty materials, remove lint from the tub after removing the laundry. Soap deposits may cause laundry to smell bad. To solve this problem, fill the tub with water and add 1 pound of water softener or 1 gallon of white vinegar; then run the machine through the complete wash cycle. If the deposits are really bad, wash the inside of the tub with a solution of household ammonia and mild detergent. Rinse thoroughly and wipe the tub with liquid bleach. Caution: Rinse the tub thoroughly before wiping it out with bleach. Ammonia and bleach can combine to form a very dangerous gas. Finally, run the machine through a complete wash cycle before you put any more laundry in.
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
How do I remove the soap dispenser draw to clean it?
In general, soap dispensers are designed to be integral to the machine. While the machine was put together by human hands and therefore should be able to be disassembled in the same way, it may very well be more of a task than you wish to take on.
This answer assumes the dispenser is basically functional and you have no reason other than cleanliness to want to remove it.
I suggest you clean the dispenser in place and forego removing the unit. I think you will be happier in the long run with this approach.
Good Luck,
Pete
Sep 28, 2015 | Indesit Genuine Hotpoint Wmf540 Wml520...
How do I clean out the soap dispenser of the washing machine?
Hi Mary,
I just did this on my Kenmore front load but you didn't identify your make or model. In my case the soap dispenser is in a drawer that pulls out and by depressing a lever the whole thing could be removed and easily cleaned.
Jan 02, 2015 | Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Water pouring from soap dispencer digital screen on mashine says H20 have drained water from pump hose at the bottom of the machine at the front
Hi from Englishman in SW France @ 18:55 Sun evening.
Although I do not know your particular machine water from soap dispenser is mostly caused by blocked tray(s).
Remove dispenser either by pulling almost out and 1) pushing down on the plastic flap at the middle back or 2) by pressing spring underneath or 3) by pulling out and lifting upwards- whichever your machine needs.
Clean really thoroughly, especially the conditioner tray and pipe contained in it- often well blocked by mixture of powder and conditioner (ours often is- I blame my wife....but don't tell her!)
The next thing- 'have drained water from pump hose at the bottom of the machine at the front'
makes me think that either 1) the drain motor lint tray/filter is blocked- which you should be able to remove and clean (if you haven't already done so by your draining action) or 2) the drain motor is malfunctioning. Normally it's the former.
Hopefully both these actions should cure both the problems.
Good luck,
John C
Feb 06, 2011 | Indesit W 123 Front Load Washer
Indesit WIE147 leaking from soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
Water in softener compartment Indesit w101 (not above)
Go to Indesit web site download user guide
http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
Most soap drawers have a plastic latch which needs to be pressed to release it.
You will find that there is a ball of soap congealed in the back of the dispenser drawer
May 25, 2009 | Indesit W 123 Front Load Washer
The fabric softner is not going into my washing machine
hi there just try washing the complete soap drawer again in boiling water leave in there for 10minutes to let the hot water work into the gaps and make sure u take all the holders out of the drawer u sometimes have to use a tooth brush to get into the small holes at the bottom of the little funnel what your softener holder goes over also get a small flat blade screwdriver and clean inside that funnel if thats not clean it will stop softener from going away if this doesnt work still then when your softener is supposed to be taken thru the programme make sure the washer opens the valve for the water to go into the fabric softener holder if it doesnt then the solenoid will need replacing as this could be faulty. LET ME KNOWHOW U GET ON PLEASE PETER
Nov 15, 2008 | Washing Machines
Lights On...Goes Out
there may be a "door closed" position switch that has been "bumped" during the process of soap dispenser drawer removal. the switch prevents accidental water leaks if door is open. your machine has a switch that is telling the control board that the door is open
May 21, 2007 | Kenmore 44832 Front Load Washer
Washing Machines Logo
880 people viewed this question
Top Washing Machines Experts
