Question about HP Officejet 5610 All-In-One InkJet Printer
Alignment Problems Whenever I start the printer, it asks to align the cartridges. It prints the alignment page and when i put the same on the scanner glass, the message 'aligning cartridges, please wait' .. keeps on flashing on the front panel and this never goes off ... .. i am unable to use the printer anyhow .. please advice
  • 1 more comment
  • ecn08 Sep 27, 2008
    Same problem even with test page placed correctly. It seems to be a problem with the scanner, does not do anything: no motion, no light....
  • Anonymous Sep 28, 2008
    I have the same problem with my 5610 all-in-one hp officejet printer. It continues to repeat " Aligning cartridges. Please wait".I truly need some assistance with this matter.
  • shari863 Sep 29, 2008
    Is there anyway to bypass the Align Cartridges function. I find it to be a huge waste of ink, but can't get anything to work unless I agree to do it, and then cancel it before it can print out the sheet. So I have to do that every time I turn on my printer.
    Problem Solver:
  • 8 Answers
I got the same message, repeatedly until i turned the paper around on the glass. I had it it wrong end up! I dont know if this will help but it took me 4 trys to figure it out.
I was trained by HP to fully support Officejets and AiO, Compaqs and Pavilion Desktops and HP Notebooks, oldest to the newest.
Posted on Sep 19, 2008
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | HP PSC 2175 All-In-One InkJet Printer
Keep getting error message from HP PSC 1510 all in one...asking to align, but aligning always fails
For completing alignment both print cartridges need print in good quality.After the alignment page is printing put it on the scanner glass to way as shown on the page and press scan button.If not help replace the cartridges and try again.
Nov 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
I changed the ink cartridges and now the alignment process cancel
hi
take out the cartrdiges
put them one by one,start wih putting the black and the color in their respective slots
wait for the printer to automatically print the alignment page,it might even ask you to put the alignment paper on the scanner bed to complete the alignment ,also you can print an alignment sheet from the computer by going to the prntr iconin the control panel's printer and faxes ,do a right click on the printer icon ,goto properties and click on printer preference.
and then click onmaitenance and print the alignment,i would insist on the automatic alignment
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Always starts up and does an alignment page.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
    after the alignment page prints then place the alignment sheet on the scanner glass and press the ok button
Jul 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Everytime I turn my PSC 1510 on it prints a test page, I have new cartridges in how can I stop it...it using all my ink unnecessarly:-(
yes, when you get test page face down the page on sccaner and press scan button after some time you get green light still, further u don't get test page again.
Jul 08, 2009 | HP PSC 1315 All-In-One InkJet Printer
Alignment of cartridges
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Apr 17, 2009 | Lexmark All-in-One Printer with PictBridge
In starting 1 page print
I believe that after changing the ink cartridge you havent completed the alignment process.This Alignment test page will print everytime you turn the printer ON.To Complete the alignment follow my steps.
1.After turning the printer ON, wait untill the printer prints the Alignment test page.
2.Then place the alignment test paper on the scanner, facing down in a correct position.
3.Then press the Scan button(color) and wait untill the printer ON light stops flashing.
4.After the light stops flashing, take the paper out and the alignment process is completed.
Turn OFF and turn On the printer, it will not print the Test page again.try it and please let me know.Would really appreciate your rating for my solution.
Thanks
Riz.
Apr 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
261 people viewed this question
Ben Johnson
