Question about Sony Cyber-Shot DSC-P93 Digital Camera
Lens wont open
Pressed the power button but lens wont open, makes a buzzing sound .flash sign is flashing. after a while it says on screen .turn the power off and on again.tried all this but still wont work
    Genius:
  • 2,985 Answers
Motor drive is shot- tell Sony customer support Be prepared to but a new camers when you see the repair quote.
Posted on Jul 31, 2007
SOURCE:
My Sanyo flat screen wont turn on but the oower button is flashing
The flashing indicator could be a sign that the power supply is unable to turn on.
Jan 10, 2015 | Sanyo Televison & Video
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Sony vaio PCG-61211M wont turn on and the power button starts flashing on and off
This can be a sign of a discharged battery, and this may be due to a faulty adapter or the connection in the laptop.
Dec 13, 2013 | Computers & Internet
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
Settings wont change
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Flashes turn off and on in the LCD. beep sound
Hello!
Please consider the troubleshooting given below:
(a) Remove the Battery from the Camera then press and hold the power button for 30 seconds.
(b) Reinsert the Battery pack and turn ON the Camera. Please make sure that the Battery pack is fully charged.
(c) Next, try resetting the Camera to the original factory settings if the menu options are accessible on the Camera.
Perform the steps given below to reset the Camera to the original factory settings:
(i) Press the Menu button on the Camera to access the menu options.
(ii) Press the right arrow on the control button to select (Setup) setting, then press the right arrow again.
(iii) Press up/down/left/right arrow to select the Setup 1option.
(iv) Next, select the Initialize Option and select OK.
Performing the above mentioned steps will reset the Camera to the original factory settings.
If the issue persists even after performing the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Buzzing sound, wont come on!
Don't try and manually push in the lens at first...the buzzing is a warning letting you know that something is wrong with the camera. By accidently removing the batteries during shut down you interupted the shut down sequence. Try and turn on the camera and immediately press the play button on the back. This should reset the camera. If not and if you are under warranty it needs to be serviced. If you are not under warranty then you can try and push the lens down. Don't use a lot of force but try and gently do it.
Jun 09, 2008 | Cameras
Won't Power Up
I have the exact same issue. It needs to be returned to the manufacturer. Make sure you have your receipt or they wont take it back if it was made after the manufacturing date (Mine was made in April 2007). The warranty only lasts one year from purchase. You have to call them and get authorization for the return. Good luck!
Dec 13, 2007 | Polaroid i531 Digital Camera
Sony Cyber-Shot DSC-P93 Digital Camera Logo
179 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
