Question about HP Color LaserJet 2600n Printer
51.22 error According to the manual it may be a hardware problem. Turning off and on and initialising makes no difference, it continues to read 51.22 error.
    Novelist:
  • 217 Answers
51.22 Error Turn off then on Error message 51.22 Error Turn off then on Description Magenta laser scanner error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
If the above doesn't work, it's the laser unit that is faulty - from about £30 for the part (if you look for and ask people who supply parts for these printers on auction websites), but a bit of a pig to replace. A good 2nd user machine might be the most expedient solution.
Posted on Sep 17, 2008
Displays operate IT according to print
That is a Casio error which usually appears when the machine hasn't finished initialising. Run through the init procedure in the manual. If you don't have it, there are plenty here:
http://the-checkout-tech.com/
Feb 01, 2014 | Casio Parts Cash Register PC Desktop
Why does the screen read "device error" when I turn it on?
http://is.gd/B05L6B
According to the user manual for the device, on page 81, it reads:
If any of these errors occur, turn the the unit power OFF and restart it.
If these error message continue to appear, please contact a TASCAM Service Center.
***Device Error*** (the one you're asking about)
FileErr
FX Busy
FX Rx Failed
I
/F Error
Mount Error
SaveParam Fail
SD-Card Error!
SD Not Found
SD Read Busy
SD Write Busy
Looks like your unit may require servicing at an authorized Tascam service center.
Good Luck!!
Oct 12, 2013 | Tascam DP-03 DP03 8-Track Digital...
Thank you for contacting FixYa with your inquiry.
The HP4700 Printer The HP 4700 is a family of color LaserJet printers intended for use by work groups and small offices. The printer itself differs little from model to model with accessories including wireless printing options and various paper tray configurations.
Error Code 'Service Error 49.2' According to the user manual, 49.X error codes mean, "a critical firmware error has occurred." Firmware is Software that ties to specific hardware components. While occasionally this means hardwired programming, installed drivers often feed programming and instructions to modern devices.
Correcting the Error Firmware errors can often be corrected by turning the device off and on again. If this fails to correct the issue, reinstalling the driver software may correct the problem. If the problem persists, HP technical support should be contacted.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Dec 07, 2010 | HP LaserJet 4700 Printer
Error 00161 00163
[CHANGE YOUR CMOS BATTER WHICH IS INSIDE YOUR CPU CASE]
I do not think you fixed the CMOS battery - (backup battery = CMOS battery)
According to the error codes, you have a dead backup battery and the time is not set. Makes sense?
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Go to www.ibm.com Find and download the user manual, and the "hardware maintenance manual."
Do you know how to get into bios/setup?
Start with the machine OFF. HOLD DOWN and CONTINUE TO HOLD THE "F1" key.
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1"
This will get you into the bios "setup." You should check the date, bootup order, etc, and reset.
I would check the "wire" you think you reconnected---you may just not have actually reconnected it.
The "hardware maintenance manual" shows you how to maintain this machine, and it explains the meaning of the error codes.
This will get you started on looking for the manual:
http://www-307.ibm.com/pc/support/site.wss/multiplefiledownload.do?validate=true
May 16, 2010 | IBM ThinkPad 380ED
Phoenix bios two long beeps one short then continuous long beeps, no video. Foxconn mobo C1 LED post error.
According to:
http://www.pchell.com/hardware/beepcodes.shtml
sounds like a memory problem. Take out all your memory cards and replace them one at a time (in different slots) until you find a configuration that works. then add in the other cards until you get the error message again.
Jan 04, 2010 | Computers & Internet
Error 00161 00163 unit comes on and shows this screen any imput would be great thanks
WHILE STILL HOLDING "F1", turn the power on, and CONTINUE TO HOLD "F1" This will get you into the bios "setup." You should check the date
Nov 21, 2009 | IBM ThinkPad 600E 2645 Notebook
Nikon LS 2000 scanner is reporting a hardware error
Hello Mike,
According to a previous post this is your answer by:
johnmichaelc
The symptoms of stepper motor failure are a loud grinding noise during scanning followed by the enlightening message:
"The scanner has reported a hardware error. The present function cannot be continued. Sense: 0x04620000"
Oct 29, 2009 | Nikon LS 2000 Film Scanner
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Will not record disc-to-disc
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Apr 04, 2008 | Philips CDR796 2-Disc CD Recorder
HP Color LaserJet 2600n Printer Logo
2,040 people viewed this question
Ben Johnson
