The rapid and the on lights are flashing - Washing Machines
    Genius:
  • 1,239 Answers
Hi
The lid switch on a washer often serves as a safety switch.
Posted on Sep 13, 2008
I have a 2008 F350 6.4 diesel with no crank no start pats light flashing rapidly and airbag light flashing
you must disconnect the battery for 5 minutes then when you reconnect the cables press the alarm deactivate button on your remote I believe your car will start and when you see the pats light rapidly flashing the cars in theft mode and will not start
Nov 04, 2016 | 2008 Ford F-350
I have sourced out all fuses and bulbs, yet continue to have a rapid right turn signal. I don't know where else to look. help?
replace the right rear bulb. the quick flashing indicates a bad bulb. it could be a wiring problem to the rear for the signal light that you will have to check out starting at the socket and working forward.
Mar 29, 2015 | 2005 Chevrolet Uplander
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Why does the red light om my 2002 crown vic flash fast when I attemp to start it
Which red light? The one on top of the dash? If so, there are two cases where that light will flash rapidly: If you use the wrong programmed key, it will immediately start flashing rapidly when you turn on the ignition and try to start the car. If the light is steady and then starts flashing rapidly after a few seconds when you turn on the ignition or try to start the car, you are using the correct programmed key but the engine computer has a problem or has failed.
May 31, 2012 | 2002 Ford Crown Victoria
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Day time running light flash rapidly when car is put in gear and stay off. SERVICE light stay on. what could be the problem?
well if the daytime running lights flash fast then stop that means there is a problem with the DRLs,usually a burnt out bulb,,check tha firstif all ok check if there are any trouble codes in the computer
Oct 13, 2009 | 2002 Pontiac Sunfire
LIGHTS ON MODEM ARE FLASHING RAPIDLY, HAVE CHECKED POWER SUPPLY AND PUSHED RESET BUTTON, NO CHANGE
You will have to be a bit more clear on which lights on which model of modem is flashing rapidly.
Usually, as long as the internet works, the flashing lights are there to show that the modem is functioning properly and is currently sending packets, transmitting data, etc.
Jun 19, 2009 | Actiontec (GS503AD3-01) Modem
Guitar hero world tour for ps3
i had the same problem but with trial and error i came up with a soulution
1. Turn on the Playstation 3
2. Plug the dongle for the drum set into an open port on the PS3, the light will begin to flash slowly.
3. Hold down the button (where the light is flashing) on the dongle until it begin flashing very rapidly. Release the button and the light continues to flash rapidly.
4. Hold down the PS button on the drum set until the red light starts flashing rapidly.
5. Within a few seconds you will get a solid light on both the Guitar Hero World Tour Drum Set and the Playstation 3.
thanks
Jan 04, 2009 | Video Game Consoles & Games
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
