Question about JVC TH-M606 System
Subwoofer JVC TH-M606
The subwoofer cuts out when the system is turned on. System does not work as a result. What causes this? Is there a fuse?
  • 4 more comments
  • Randy Wells May 22, 2006
    The system doesn't power up. The subwoofer powers up and clicks off in a second or two. The subwoofer came with the JVC TH-M606 system. There are no add-ons.
  • ztmdad Nov 06, 2007
    IF THE VOLUME IS ABOVE 40 WHEN WATCHING A MOVIE OR LISTENING TO CD OR RADIO THE SUBWOOFER SHUTS OFF. THE MOVIE WILL CONTINUE PLAYING, BUT YOU HAVE NO VOLUME. I HAVE REWIRED SEVERAL TIME TO NO AVAIL. ONLY THING THAT WORKS IS TO HAVE THE VOLUME AT ABOUT 20 DURING NORMAL VIEWING, SO THAT WHEN A CLIMATIC SCENE COMES ON YOU CAN CONTINUE WATCHING MOVIE.
  • TarraSann Dec 29, 2007
    Mine does the same thing.. I have had it worked on 3 times only to be told it is the design. The connection in the back is bad and there is nothing that can be done for it?
  • Anonymous Mar 09, 2008
    The subwoofer clicks off a few seconds after being turned on. There is ** sound through the other speakers.
  • murrelet Jul 15, 2008
    I have the same problem. The unit has been in use for the last three years, nothing has changed as far as the wiring goes. In the last month the sub woofer unit started to just click off occasionally. Tonight the woofer would not turn on.
    Turn off system, turn on system, green woofer light turns on for a second or so then clicks and turns off, everything else remains on and seems to be working fine. Having no SW means NO sound, period.
  • jemshirl Jul 31, 2008
    The subwoofer suddenly stopped working. Other speakers fine. Seems might be a bad connection - how do I remove the side of the subwoofer on which the speaker's mounted? I remove the four hex bolts but it's still on tight and I don't want to force it.
So how can i fix the fuse
Posted on Sep 17, 2012
Posted on Jul 31, 2008
    Scholar:
  • 116 Answers
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
Posted on May 19, 2006
  • Bill DeLisi
    Bill DeLisi May 23, 2006
    First, I would disconnect everything and start over. The easiest thing to do (my engineers and I have as well) is to make an error on the wiring. Also check the fuse, which is in the back of the system (underneath the housing, so you have to remove it) And check to see if there are any cuts or breaks in the cables. Let me know how it works.
I have a jvc th-m606 receiver and I don't have a subwoofer for it, is there a different way for me to get audio output or a different subwoofer I can use?
You would have to make a cable that goes from the 8 pin mini din of the jvc unit to each individual speaker. A wiring diagram can be found online each pin on your 8 pin goes to a speaker , and one is for power. Find a wiring diagram and find a cheap electric store that can make the cable for you. I had the same problem...
Aug 10, 2012 | JVC TH-M606 System
WHERE CAN I BUY A SP PWM505 CABLE THAT GOES FROM MY RECEIVER TO THE SUBWOOFER? ITS A HOME THEATER
  • Here is a list of cables for your unit from Crutchfield's.
  • If your looking for the s pin DIN cable from the sub you can get that anywhere. The 8 pin DIN is a standard cord the same across the board. Here are a couple to choose from.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Oct 11, 2011 | JVC TH-M505 System
I CANT FIND A SP PWM505 CABLE
Regards, Tony
I need a remote for my TH-M606 subwoofer, how do I get a replcament?
encompass .com formerly vance baldwin .com will sell jvc to the public..
Sep 08, 2010 | JVC TH-M606 System
Subwoofer clicks and quits
The power amp that drives the subwoofer has quit. This will require repair. It is likely that the replacement you got from Ebay was defective as well. Not un-expected as I get stuff to repair from there all the time.
Your original unit failed in a manner to shut down the power supply. The replacement has a good power supply but a only fried sub amp.
Aug 10, 2009 | JVC TH-M606 System
Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Jul 14, 2009 | JVC TH-M606 System
Hello, I have all working speakers for the JVC TH-M505 home theater system, but the control center/receiver gave out. Do you know if I can use them with the JVC TH-M606 HomeTheater Control Center? Thanks...
If the JVC m606 requires a stipped wire to connect them then they should be fine just make sure you connect the right speaker to the proper output if your speakers have a specified connector on the end then you would have to cut that off and strip the wire. if your m606 requires a specified connector for the speakers then you would have to change the connectors out for the proper ones.
Mar 07, 2009 | JVC TH-M606 System
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
Subwoofer not working
http://support.jvc.com/consumer/product.jsp?archive=true&pathId=30&modelId=MODL027222
cut n paste the link for the manual
Are headphones plugged into it?
Is the headphone jack damaged?
Are there speaker fuses on this model? If so, check them.
Dec 06, 2007 | JVC TH-M505 System
WOOFER NOT WORKING JVC th-m606
I'm having the same problem. It seems that the mosfet's shorted blew up a capacitor and took some surface mount parts with it. It will be the middle board with the metal shroud (shield). The mosfets are almost impossible to find, I have replaced them (as well as other parts) but still have yet to find the problem. I'm now trying to find the subwoofer amp board (part#LVA10505).
Dec 02, 2007 | JVC TH-M606 System
JVC TH-M606 System Logo
855 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
