Water pouring out from soap tray !!!
Last week when a wash had finished there was still water in drum , thought it was a one off. then went to put machine on again and water started pouring out from the bottom part of where soap tray compartment goes in
Took soap tray out and there was water still filled up to the top of hole where the water would usually take soap into the washing drum..it seems there is a block between there and the drum as no water is going into drum.
its sod law as warranty ran out a month ago,
Could someone please help or has any ideas what I can do
Thanks
  • pipcnd Sep 13, 2008
    Thanks, thing is Im not technically minded, and wouldnt know how to or where the things your talking about are...all I know theres a blockage in the washing machine , the water is not going through to after soap meets water hole into drum to wash clothes..i was hoping to hear its the pump. , open that and the blockage will be fixed..lol
    Genius:
  • 1,239 Answers
Hi Water leaks in a washer are often difficult to trace. There are many possibilities to look for. The problem could be a loose connection, a broken hose, a cracked component, or a defective seal. It could also be a hole in the tub. If a hole in the tub is the problem, it's usually best to replace the washer.Most leaks can be eliminated by tightening water connections and replacing deteriorated components. To stop a leak:
Step 1: Check the lid seal. If faulty, replace with a new gasket.
Step 2: Check the hoses at faucet connections. Tighten connections or replace hoses.
Step 3: Check the hoses at water valve connections. Tighten connections or replace hoses.
Step 4: Check the drain hoses. Tighten connections or replace hoses.
Step 5: Check the inlet nozzles. Tighten connections or replace nozzles.
Step 6: Check the splash guard. Tighten connections or replace.
Step 7: Check any plastic valve. Tighten connections or replace.
Step 8: Check the outlet hose to drain. Tighten connections or replace hose.
Posted on Sep 13, 2008
How do i make my samsung diamond washer model WF8500NHW use more water in the drum when washing a load
The amount of water in a washing machine is measured to be the optimal amount. If the clothes do not clean, perhaps you should reexamine the powder.
Feb 14, 2015 | Samsung Washing Machines
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Washing machine is leaking
Could be blockage @ soap hose going into the drum..Clean.
Apr 07, 2010 | LG WM-2277HW Front Load Washer
The water to my washer stopped when I closed the lid; now it won't resume filling the tub. What to do? (I have water to other places in the house.)
Try pouring water through soap tray without spilling. you can finish the cycle now. Thereafter check your inlet water connection for free flow.
Apr 01, 2010 | Washing Machines
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
I was washing a load of clothing and when i went to check, water was pouring out of the space underneath the soap dispenser
The dispenser connects to the drum via a flexible hose, which sounds like your problem. Unplug the washer and remove the tray. Open the top and inspect your connections and hoses.
Regards,
--W/D--
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Soap tray does empty
Try pouring some really hot water into the trays and running a quick wash.
Aug 18, 2008 | Washing Machines
Water coming from soap drawer
take back off machine, at the bottom of the drum is a very large clip slacken off and clean out fillter (looks like a bellows)
you will find a lot of muck in the filter
did this last week and its now running ok
ian
Feb 08, 2008 | Ariston Technologies AWD121WH
Washing Machines Logo
305 people viewed this question
Top Washing Machines Experts
