Question about Maytag PYE2300AY Electric Dryer
Maytag dryer PYE3300AYW Continuously runs
My 5 year old dryer will not turn off. I must open the door or turn the knob to the off position.
Timer advances but keeps the dryer running , replaced timer and still have the same problem. 1--5-08
Posted on Jan 05, 2008
    President:
  • 878 Answers
Jefo, it sounds to me like your timer is not advancing. Does it move at all or stay in place? In what you are saying it will stop when you turn it to off, I would think it could be the timer that is the problem. Part # 53-1810.
Posted on May 19, 2006
I have same problem. Timer advances, but doesn't stop at the proper settings.?
Posted on May 14, 2008
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Maytag_Owners_Manuals PYE3300AYW
For the dryer to take to long to dry is usually a sign of the vent duct work being restricted with lint. Check the vent hose, outside vent door, and the internal duct for lint buildup.
Oct 21, 2011 | Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
No power to the dryer.just stopped working no waring maytag pye3300ayw
If there is no power at the wall outlet ... lease check your power panel for a tripped circuit. Reset it by moving the handle to the off position and back to the on position. If you turn it on and it trips again, you need a professional electrician to repair the short that evidently exists somewhere in the line.
Mar 08, 2010 | Maytag PYE3300 Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa pye3300ayw dryer
Check for burnt or loose wires at the junction where the power cord attaches to the dryer. Also check the door switch. When you open or close the door you should hear a click, that usually means the switch is ok. Then open the cabinet top and check for broken wires.Check unit with power off / cord unplugged!!! Safety First. Good luck. BpB
Aug 16, 2008 | Maytag PYE2300AY Electric Dryer
No hot air
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
Jun 11, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
551 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
