SAMSUNG LE32R88BD Colours are going very dark, background black, people red. images blur as they move. Fixes itself temporarily then goes back.
  • 121 Answers
SOURCE: Samsung 40" LCD 1080p
Yes, it's not uncommon. It also depends a bit on the TV. Some are better than others. There is a connection between price and quality, although it is not absolute. What kind of equipment are you using? DVD, satelite tuner etc, and how is it connected? (scart etc)
Colors can be adjusted from the menus (se your manual for reference). I've never seen a TV that don't need color adjusting before it gets good, as color experience will vary with room coloring and light, etc.
Posted on Dec 05, 2007
smilemaker
  • 790 Answers
SOURCE: Dark Screen and Blue Lines Arc Across Background
Hello!!
If the coolant is cloudy or has debris floating in it, the coolant will have to be changed and the lenses and crt face will need to be cleaned. Coolant can be ordered from any electronic distributer
Posted on Dec 28, 2007
SOURCE: 2605dn prints red background randomly
From the Adobe support web site:
Solution to the red box problem:
http://www.adobe.com/cfusion/knowledgebase/index.cfm?id=kb400692
Posted on Jan 21, 2008
edo333
  • 55 Answers
SOURCE: 2 left side red 1/2 ring ligts
These two lights are actually an indication of overheating. Typically this happens if the heat synch is not making good contact with the cpu or gpu, or the cooling fan is not working properly.
If the fan gets really loud just before it overheats and turns off then it is likely a heat synch issue
You can try searching for the xclamp replacement fix (I won't leave my own tutorial here as there are a plethera of them out there, just use a search engine to find them)
If the fans do not make noise - it may be that they are not working properly, you may want to replace it with another cooling fan. Talismoon fans are widely available and very quiet.
Try cleaning the console - dust and debris trapped inside the console traps heat as well.
Other than that if the console is usuable for more than a few minutes and it overheats after an hour or more, then you can try removing the heatshield (metal piece located under the top plastic cover) and or replacing the cooling fan with a more effecient fan. Please note that removing the heatshield is not recommended as it protects the top of the console from the extreme heat built up by the console, but removing it does allow for a much more significant amount of air flow.
Try and keep the console off the ground - along with the power supply
Play it horizontally instead of vertically and keep it away from carpets which trap heat and other sources of heat.
As always contact microsoft for warranty info prior to opening the console or letting someone else fix it for you.
Hope that helps.
Posted on Jul 04, 2008
mediarich
  • 188 Answers
SOURCE: Mitsubishi WD-52631 shadows and blurs in dark lit movies
If you are getting the same problem with both TV monitors it could then be assumed it's an input problem to the TV monitor. If you are using a digital output from your receiver it could be the cabling. If you are using an analog output from your receiver it is probably coming from the receiver.
Digital video processing does have issues with darker scenes.
Can you try another video source seperate from the receiver like a DVD or better yet an analog VHS, if you still have one. Good luck and let me know.
Posted on Sep 17, 2008
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
Black shodows on screen. Visible w/ every source...less visible with bright background...very visible with medium to dark blue background. Have seen a lot of complaints on the Internet related to this...
This problems only two posibilities,one some how u got a light image burn in into the LCD screen panel itself.If it is the LCD screen burn in,this is not repairable.The other one it could be the T-Con decoders board problems and it dying this board sit wright at middle at the bottom of the LCD screen panel to decodes and regulate pictures as it passing and go in and out of the LCD screen panel itself.Tries websites like Shopjimmmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement,possibilites could solved ur light background shadows problems.
Dec 07, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Ixus 430 rear screen often goes blurred with odd
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info. Also check the Canon website if you're not in the U.S. as this is a worldwide advisory.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Sep 23, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Blurred image
This sounds like CCD sensor problem ( especially if the picture is "noisy" ). Canon and Sony fixes this particular problem free of charge since the CCD device installed in your camera should last + - 15 years if it is properly manufactured. Contact your agent and find out what their policy is.
Aug 19, 2008 | Canon MV650i Mini DV Digital Camcorder
My new Samsung LE32R88BD was showing a pixellated picture on movement, but it filled the entire screen. Since switching my Virgin box through HDMI, the picture is less pixellated but I cant get the picture...
I did some reading on the net, try to "calibrate the screen". Try set the input to 1080i, then run the thx optimiser to give you a starting point, then try a bluray with a bright image.
Keep replaying the same chapter and try raising and lowering different settings. you may find that your brightness is set way too high and after dropping it from 90 to 29, you may find that detail will have crept into the image. Try giving the colours a boost as well.
The detail in HD is very subtle, and having a properly calibrated screen will make all the difference. So to answer your question: set your input to 1080i, make sure your HDMI is outputing RGB and start tweaking that screen!
Mar 08, 2008 | Televison & Video
Picture colour problem
Hi, apparently there appears to have been an issue with a Sony Component in the F401, see the following URLs for more information: http://davesgarden.com/place/t/552292/ http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true I am in Europe and experiencing the same issue with images coming out black and white and blurred. Hope to find some local support. Take care, Stephen
Sep 03, 2006 | Fuji FinePix F401 Digital Camera
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
