All lights flash on front of wahing Machine, it tkes for ever to try and start the cycle. When it does start, all the lights continue to flash repeatedly. It does complete the cycle though. The washing machine in question is Hotpoint WT746 7KG model
  • scorgan Sep 13, 2008
    Ok, Thanks for the quick response, will try that when cycle is finished and let you know the outcome.
    If it's a faulty control panel, can these be replaced easily? Are they expensive?
  • scorgan Sep 14, 2008
    Still does the same thing, all the lights continue to flash on the control panel. Forgot to say, I am from the UK and can't seem to find my Washing Machine listed.
    Hotpoint Ultima WT746
  • Washing Mach... Master
  • 19,396 Answers
Try first unplugging the power cord for thirty minutes.
If the error does not clear then it is probably a faulty control panel.
When the fault is on a different part (eg. pump, sensor etc.) you get an error code.
You can find the replacement control/timer assembly here.
If you need to call repair service you can use the number printed at the end of the owner manual.
Posted on Sep 13, 2008
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
All lights flash when started
try a different socket and try not to use extension leads if the lights continue to flash do not worry for now . the balance problem could be uneven load . or get some one to remove top and check support springson top and dampers at bottom are still in place . and concrete weights are not loose .
Feb 11, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
AWM6140/3 Wahing machine
it's a prgramme timer issue mate, you either need the timer flashing with updated software or a replacement timer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Error Code "TEST"
Just had the same problem & found the following solution via the web :-
1. When tESt shows hold down both the ON/OFF Button & the START Button together & let the Test proceed holding the two buttons down for the entire test (Approx 3 Minutes ) .
Continue to hold the " buttons down until the word Done appears.
After which you should be able to proceed with the normal wash cycle
May 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing lights
I've also been having problems with my Whirlpool. Try to turn off the power (unplug, flip breaker whatever) let the machine "re-boot". Then start the cycle again.
Good Luck!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
All Lights Flashing on Hotoint Aquarious WF310 Washing Machine
Means that the heat sensor is broken.
Replace that and it should fix your problem
May 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Oct 30, 2007 | Neff W4380X1 Front Load Washer
Washing Machines Logo
166 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
