Question about Zenith Z35X21D 35" TV
Zenith model SR3587 Picture too wide
After getting several bright flashes, picture went black then more flashes followed by a centered, verticle line, then black again. A few seconds later the picture came back, but it is too wide for the screen. FAces are broad, scripts are cut off an either end. Verticle seems ok.
    President:
  • 3,130 Answers
There are a couple of coils that are for pincussion and width that get cold solder connections on them and sometimes will blow out the curcuit. Maybe its not to late to resolder them? Good luck
Posted on May 19, 2006
Panasonic Plasma screen suddenly has a verticle black line
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Verticle black bars
Check the connections on the flat cables to the screen. Be sure first to disconnect the power supply from the x and y sustain boards before you disconnect any of the flat cables.you will burn the cables from the stored energy in the power supply, also check cables on c boards at bottom of screen. If this does not fix probably bad panel.
Apr 24, 2009 | Televison & Video
No picture, black screen
Not a TV Technician, use the following information at your own risk. Two things you can do first: using the keys on the front of your set press and hold the menu button when while holding it down it goes from menu to channel listing press the adjust (<->) and channel up buttons simultaneously to get to the factory set up screen once there use the select button to scroll to next set up screens locate the contrast it should range from 1-63 find the one you like. Second: for the horizontal lines not to say that this is the solution there are two adjustment apparatuses inside the TV chassis if your familiar with taking the set apart and not getting shocked and hurt59274cc.jpg two dials on the fly back transformer ones for focus the other brightness you can try these fixes but I have to say again that you use at your own risk. I do hope though that the information is useful
Mar 18, 2009 | Zenith B25A02Z TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Logik lt2974 small picture
the problem is in the verticle section, if you are a technician check a verticle IC and a capacitor of that stage. to allocate a verticle stage follow 4 cables coming down from deflection coils, two of these wires goes near transformer, this is horizotal and the other two goes near an IC this is verticle. positive idea.
Nov 22, 2008 | Zenith B25A02Z TV
Picture Greatly distorted all of a sudden by many yellow lines
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Jul 07, 2008 | Zenith D61W25 61" Rear Projection...
Verticle lines
You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Vertical size of picture
You have a number of bad capacitors in the vertical circuit. If you can solder, you should be able to repair this yourself. I'll look up your model to get the parts needed.
Dan
Jun 02, 2008 | Toshiba 36A50 36" TV
Bowing in the middle like an hour glass
about the zenith it seems you have the flyback transformer malfunctioning - try to change it - delfo
Mar 22, 2008 | Televison & Video
Green light blinking- no picture
This just happened to my Z50 yesterday...10 days after it came back from the repair shop! The first repair was for the "popping" problem where the tv makes a loud pop and the screen goes black. This took 6 weeks to get fixed. For this new problem the repair center is getting hold of LG to find out what to do. I am also calling them because I see this is a major problem that people have been experiencing out of warranty. The first customer service rep told me I was out of luck but I am not accepting that answer. Good luck, we'll both need it.
Feb 05, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Televison & Video Logo
73 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
