Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
DWL-G710 repeater without does not recognize network
I've set-up my 710 range extender, unplugged the cable and was ready for magic. Vista found the new 710 (significantly improved signal) however, keeps identifying the network as "unidentified".
I have (only) WEP encryption so that's not the problem - it seems to me that the unit is not connecting with the base station also from D-link (DSL-G624T).
Any ideas?
  • Anonymous May 16, 2009
    literally the exact same problem on my end
    i have no idea what to do about it
  • 5 Answers
SOURCE: DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
Posted on Jun 08, 2007
  • 48 Answers
SOURCE: D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Posted on Feb 10, 2008
  • 48 Answers
SOURCE: DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
eng_darwish1
  • 233 Answers
SOURCE: DWL-G710
check the dial-up configuration settings. via the admin web page for that DWL-710 gateway
Posted on Jul 07, 2008
  • 742 Answers
SOURCE: How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Posted on Oct 22, 2009
192.168.0.30 for DWL G710 does not respond
hi r_raiche
1. Take a regular ethernet cable and plug it into the ethernet port of your computer
2. Plug the other end into ethernet port of the DWL-710
3. On your computer (assuming you have Windows XP Pro with the NON-classic start menu), go to Start > My Network Places
4. On the top left under "Network Tasks" click on "View Network Connections"
5. Right click on "Local Area Connection" and then down to "Properties"
6. A pop-up window with 3 tabs should come up. Under the "General" tab, there is a list of icons with checkmarks next to them. Highlight the "Internet Protocol TCP/IP" on and click the "Properties" button underneath
7. Tick "Obtain an IP address automatically" and "Obtain DNS server address automatically"
8. Click on "OK" then "OK" again
9. Open up Firefox (or IE) and type 192.168.0.30 into the URL field
10. Type in the default username and password
Jul 07, 2010 | D-Link AirPlus G Wireless Range Extender...
Can't access the internet. No problem with the static IP address and setting up the DWL G710. Searched and found 2 AP's for my wireless account. Selected one and saved. Got indication that DWL G710 was...
Is there any particular reason you're using a static IP? Most routers are set up already for DHCP.
If you need to use a static IP, make sure you have the right settings for the default gateway and DNS servers (you'll have to contact your ISP to find out the addresses for the DNS servers).
I would recommend switching to DHCP though, and you won't have to worry about such settings.
Aug 02, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Setting up my DWLG710 EXTENDER
You need to give IP add manually to any of ur PC as 192.168.0.31 and than open DWLG setup page on the browser by typing 192.168.0.30. It will bring the setuup page of Extender.. on this page change the IP add from 192.168.0.30 to 192.168.2.50.. it will restart ur extender and make it working in same network... roll back the changes u made to ur PC to connect..
Feb 04, 2009 | D-Link AirPlus G Wireless Range Extender...
No internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
Oct 18, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Setup range extender
Access pointe bağlanmak için öncelikle bilgisayara elle ip adresi vermek zorundasınız daha sonra cihazı ethernet yoluyla bağlayarak ayarlayabilirsiniz.Ancak modeme bağlarsanız ip adresini ayarlamak gerekmez.Kolay gelsin.Good By
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
DWL-G710
Jun 27, 2008 | D-Link AirPlus G Wireless Range Extender...
G710 and Vista
G710 does not support WPA2 it will only repeat from a router running WEP
Mar 19, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
226 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
