Audio driver needed to make my Audio 350 microphone/headset work. the mic is not working. brand new. I accidentally just uninstalled my audio driver. Vista
    Champion:
  • 214 Answers
Hi, go for a system restore to get back your audio controller driver.
thanks
Posted on Sep 13, 2008
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
I have a compaq presario v3700 with windows xp.It has conexant high definition as audio. I plug in my headset. It works in terms of audio hearing on headset but u can also hear it on computer. Then my...
Don't think its the drivers, because you can hear audio.
Do you have your mic with your headset or separatedly? If with headset, maybe your headset has a physical switch where you can enable/disable mic (seen this feature on some Locitech headsets).
You can also check whether you have Mic muted in your audio control panel. Go to Control Panel, open Sounds and Devices and File - Properties if I remember correctly (sorry, I have Vista now) and put a check before Mic property to bring out the Mic volume level bar to see whether it's muted or not.
Hope this helps,
Tom
Nov 17, 2009 | HP Pavilion dv9000z Notebook
Crackling Microphone
Vista always has sound card problem.
I had too because with my headset (microphone) It works through your sound card
but it works well now after I installed it as below
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=US&swItem=ob-78911-1
ADI SoundMAX Integrated HD Audio Driver for Windows Vista
Hope can help
Jun 19, 2009 | Logitech (980240-0914) Consumer Microphone
I just bought a GE Portable headset with detachable MIC
I had the same problem, but fixed it. All you have to do is:
(I have a Dell Laptop)
1. Go to the control panel
2. Go to the sounds, speech and audio devices
3. You are supposed to see the icon that belongs to your sound card (Mine is SigmaTel Audio), click on it
4. Activate the port where the microphone is connected, close
5. Configure your microphone as you normally would
6. It should work
Oct 10, 2008 | GE (JASHO97748) (3 Pack) Headset
Microphone(MIC)Of head set not working(got removed wrongly)
This usually just gets reinstalled whenever you restart your computer be it Vista or XP. In your case, the drivers for the Microphone probably got deleted. The Microphone driver comes in the package together with the sound card. You'll have to re-install the whole sound card driver to have it start working again. You can do this from the Device Manager. After doing this, the microphone together with the whole sound card drivers should start working again.
Sep 17, 2008 | ASUS M2N-E SLi Motherboard
Microphone not working
try reinstalling audio drivers
log on to
www.suppport.dell.com
click on drivers and downloads
enter your system's service tag
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
download latest audio drivers
save it on your desktop
go to device manager and uninstall audio drivers
restart your system
now install the latest audio drivers from your desktop
restart your system after installing the drivers
then check if the mic is working
Jun 04, 2008 | Dell Inspiron 6400 Notebook
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
Microphone is not working windows vista
My microphone has always worked on vista for, I use it everyday on skype, but today it will not work, I can hear the caller but they cannot hear me. I thought my headset was broken and i bought a new one. but its still doing the same thing with the new headset. It says the microphone settings are enabled and working, but when i do the mic test, it says that it cannot hear me.
what can i do?? help!
Dec 27, 2007 | ASUS M2N-E SLi Motherboard
Microphone can be detected but doesnt work
Go to start then control pannel then sounds and audio devices. Then in in the volume tab select advanced in the device volume section. When the mixer comes up go to options then properties select the recording option a recording mixer will come up make sure to check the microphone box. Raise the level in the ixer and you should be golden. If you want to hear the mic select playback mixer and raise the mic level. Hope this helps. : ]
Dec 09, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
