Question about Nextar X3B GPS Navigation System
GPS not Working
Hey, I have nexter x3-01 gps not working when I turn on it shows similer windows like computer expect it has program, favourites, documents, setting, run, and suspend under Starts menu and My device, Version show, and recycle bin on the desktop, I dont know wher to get the software to reset it. I have tried Nexter.com but not much help is there. Pls Help
SOURCE: volume on my new nextar GPS X3-T isn't loud enough
You can buy an FM modulator at any wal-mart that will plug easily into the headphone port on the gps unit and play the sound out through the radio in your car. I had the same problem with my nextar gps but since I purchased the fm modulator it is plenty loud enough.
Posted on Jul 19, 2008
elias_sgr
  • 163 Answers
SOURCE: GPS sYSTEM
i dont think repairing a broken is the best solution. (may be high cost and not satisfying result.
Have a look at ebay also.
Posted on Aug 05, 2008
jackiaria
  • 350 Answers
SOURCE: No problem, just woder how long it takes to charge
Read your manual or assume it needs to be charged overnight (8hrs minimum) !
Posted on Feb 21, 2009
RixsFixes
  • 2200 Answers
SOURCE: GPS stuck up
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In this case you must return the unit for exchange or repair to the retail location from which you purchased it, or contact Nextar for further assistance.
For technical support for your Nextar GPS see http://www.nextar.com/frontend/support.asp or you can phone them on 888-849-0846
Posted on Jul 07, 2009
  • 18 Answers
SOURCE: my nexter x3-03 wont go pass the navigation screen
make sure the sd card has not been altered or formatted as all the information and map is on the provided SD card.
Posted on Aug 15, 2009
I need a users manual for navmii gps navigation software For Windows
https://www.microsoft.com/en-us/store/p/navmii/9nblggh10k57 = software.
Navmii used to have an old manual at http://www.navmii.net/bin/Navfree_UserGuide_v1.0.1.pdf
The link no longer works.
Here are some basics:
Basic Navfree Help
Navigation is easiest if locations are added to Favourites before navigating. To check a location before adding it to Favourites, or find a location near another location:
Tap Menu icon at bottom right of map screen. Tap Navigate on Main Menu. Tap Address or Google.
Type name to find. Done. Tap down-arrow beside item . Tap Show on map.
Check it is the correct place. If so tap down-arrow and Add to Favourites.
Or drag map to required location. Tap on map. Select Add to Favourites. Change name if required.
To enter a route from A to B, when A is not the current GPS location.
Need to disable GPS in Android Settings - Location.
Easiest if A and B are entered into Favourites. Use Google Search or Address to find names and descriptions, then Add to Favorites.
Then tap Navigate on Main Menu. Tap Favourites and select A.
Tap box with Favorites name in it, and select 'Route from Here'.
Tap Menu icon at bottom right of screen. Tap Navigate. Tap Favourites.
Tap 'Route here'. Tap 'Selected' (not Gps).
Tap 'My Route' to see Route on map.
To clear route: From Main Menu, tap Clear Route.
Cant edit or delete (sometimes) Favourites. Use Jota app . See forums.
Still looking for manual, there blog is very helpful which is the link above.
Helpful links,
https://groups.google.com/a/navmii.com/forum/#!forum/android-app
https://groups.google.com/a/navmii.com/forum/#!topicsearch/user$20manual/android-app/CibF963hA5I
Nov 16, 2016 | Tablets & eReaders
DO the Garmin receivers work with Windows ?
Yes the Garmin DPS units do work with Windows. There should be a USB cable in the box the GPS came in. The smaller end plugs into the GPS and the larger end into one of your computer's USB ports. The GPS screen should come on and show the Garmin name. Then the Loading Maps title should show briefly. A graphic should show up on the bottom part of the screen that looks like a desktop computer connected to a GPS. A horizontal white line should then appear about half way up the GPS screen which should turn to green. You should then be able to see your GPS listed as a removable drive in Windows Explorer, or whatever file management program you use.
If you are unable to see the GPS unit there is a plug in available on their website called the Garmin Communicator Plug-in which should help you see the GPS unit in Windows or your internet browser. IF you still cannot see it then try and switch to another USB port on your computer. If you have anything already plugged into a USB port and your computer can see the item, then try and plug your Garmin into that port. If you still cannot see the unit then there may be something wrong with the unit or your cable. If you still have a warranty you may want to take your unit back to the store you purchased it from. Windows should definitely see the unit without having to load any special driver.
Mar 06, 2011 | Garmin nuvi 1450 GPS Receiver
My nexter x3 froze how do i fix it
try a reset at side, or rear there should be a little hole inside is the reset press it in for a few seconds this may work.
Mar 07, 2010 | Nextar X3-03 Car GPS Receiver
My nexter x3-03 wont go pass the navigation screen it only shows 3 green bars
Aug 14, 2009 | Nextar X3-03 Car GPS Receiver
No voice
hook your gps up to computer and turn gps on, load garmin program and download free voice to it from internet
Jul 24, 2009 | Garmin nuvi 750 GPS Receiver
Can I programe my nuvi205w with address from my
No, but you can save addresses in your
"My favourites folder"
Then go to "my favourites" to use the address, for quick input.
You can back this data up to your Pc too, but you can't just Enter on the Pc keyboard and transfer to Nuvi.
Regards
Richard.
Jun 18, 2009 | Garmin nuvi 205W GPS Receiver
No problem, just woder how long it takes to charge a new nexter S3 gps ofr the first time
Feb 21, 2009 | Nextar X3-03 Car GPS Receiver
Black Screen
THERE SHOULD BE A TOLL FREE NUMBER ON EITHER THE BOX OR IN THE USER MANUAL TO HELP TROUBLESHOOT. IF ITS NOT FIXABLE, THEN THE COMPANY SHOULD HONOR A 1 YEAR WARRANTY THAT COMES WITH THE UNIT. IF ITS BEEN OVER 1 YEAR, THEN SADLY ITS TIME FOR ANOTHER UNIT.
Nov 29, 2008 | GPS
Storing my favourites on my PC
You can make a new folder in my computer and click and drag your favorites there so you can keep them there. This should work.
Nov 10, 2008 | Garmin StreetPilot c310 GPS Receiver
I have poblem with my gps
i have a nextar w3g, and this gps is running with windows CE, is possible the problem to be a virus or some othe errors you can find in every other windows sistems.
Aug 30, 2008 | Nextar X3B GPS Navigation System
Nextar X3B GPS Navigation System Logo
21 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
