Question about Aiwa Televison & Video
Aiwa GX1100 VCR
VCR Display shows "SAFE" when any buttons pressed and does nothing. Is their a reset procedure?
  • Anonymous Jan 05, 2009
When safe show on the screen, it actually means that the child lock feature is on.
All you have to do is press the child lock button again on the remote and it should flash "OFF" on the screen.
Hope you have the remote :)
Posted on Sep 26, 2009
Kako da pomerim kanal na tv videa
Posted on Aug 03, 2010
What is the pin code for Aiwa HVFX5500 vcr
hi ,
Try...
Power on,
Press both CH/UP key and REC/OTR key for more than 2 seconds,
OK will appear in the display panel.
or try
Press CH DOWN key on VCR while pressing the 7 key on remote and hold for more than 5 seconds.
The display should then show OK.
but First disable the child lock by pressing the "lock" button on the remote,
and only then press "Ch-" and "7".
Oct 02, 2014 | Televison & Video
VCR won't cut on.
Clearly something wrong with the power supply on the VCR. Could be an internal fuse if nothing lights up.
Feb 24, 2014 | Aiwa HV-FX8000 VHS VCR
Need to find code for Jumbo Universal Remote to use with Aiwa S2011 MTS television. Thanks for any help!
Hello
Aiwa TV is not lited on Jumbo Universal Remote codes. Anyway try out with these codes. Sometimes may help you.
Three digit codes for Aiwa TV with universal remote are:
195/ 196
Four digit codes for Aiwa TV with universal remote are:
0195 0196 0227 0269
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your TV with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
OK
Jan 27, 2011 | Aiwa TV-S2011 20"
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 29, 2010 | 1997 Audi A4
Unlock procedure for 1998 Audi A8 matshushita/ panasonic stereo
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. Use station buttons 1,2,3,and 4 to enter the code number from your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Jan 02, 2009 | 1998 Audi A4
SAFE
Pro-Tect Plus™ Locking Feature
To disable VCR usage or to protect set timer recordings, the unit can be locked so that the
buttons on the VCR or remote control don’t work.
• To Lock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
appears in the display to indicate Pro-Tect Plus is active. SAFE also appears if the VCR is
turned on while the feature is activated.
To Unlock: Press and hold either the remote control’s ON•OFF or VCR button until SAFE
disappears from the front panel display. Unlocking is the only way to use the VCR.
May 10, 2008 | Televison & Video
LG VHS GC480W - VCR 'safe mode'
What do you do if you lost your remote?
Is there some master reset availible?
Oct 26, 2007 | LG XBR446 DVD Recorder/VCR
Vcr will not work
Try pressing down the vcr or Aux button for a long time. Then try pressing down power button on remote for a long time. Try info or display button for long time. After I fiddled around with these for a long time it worked.
Sep 29, 2007 | RCA VR355 VHS VCR
Problem with DVD-VCR combo
I found if you disconnect the power and keep it off for thirty seconds or so to let it reboot, the "SAFE" problem disappears.
Sep 04, 2007 | GoVideo Go Video DVD/VCR Combo
Televison & Video Logo
1,124 people viewed this question
Top Aiwa Televison & Video Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
