I have an Acer Aspire 5520-5334,my wireless connection used to work without problem with verizon dsl, but since I change for verizon fios I have difficulty connecting to internet, and when I am connected I lose my connection every second; can you help me fix my problem please? thank you.
  • rubrx Mar 30, 2009
    i can't connect to verizon fios - at all
    Problem Solver:
  • 6 Answers
HI,
once go a head and uninstall and reinstall the usb drivers from device manager from contorle panel and reconfigure the wireless....
Posted on Sep 13, 2008
I have a 'new' aspire one netbook and i cant make work. it says in need to be connected to a network. ihave an acerlaptop that works just fine on network 7AP13. i am connected verizon fios and am not
That means there is a corrupt or a missing wireless driver on your new acer laptop. First of all if you are using Windows XP follow the following
1. Go to start
2. Right-click on "My computer"
3. Go to "Properties
4. Go to Hardware tab
5. Go to Device manager
In the device manager check for any yellow question mark or an exclamation mark. Especially on the network adapters. That means if you had the network drivers working before, then they are corrupt or they are not there at all.
Here is the solution..
visit acer.com and go to their downloads and support tab, you will be abel to see the model of your computer and you can download the wireless drivers that are compatible with your laptop.
Nov 15, 2011 | Acer Aspire One PC Notebook
Have a new Acer Aspire 5517, when I move the computer more than 7-10' from the router the signal goes from Execellent to poor/lost connection. 5 other computers on this Verizon Fios network run great with...
Take both excuses out of the equation. Buy a wireless N dongle off ebay (you can pick them up dirt cheap).
Router would pick up dongle using it's own software (Acer's excuse) and would not know or care the make of notebook (verizon's excuse)
Sep 05, 2010 | Acer Aspire 5100-3825 Laptop Computer...
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
I suspect that Verizon is degrading service to forcr users to mig
Anything is possible but it would take a lot of work to jam wireless signals. As a communications company, Verizon, if caught would be in hot water with the FCC. I have an idea. Are you able to change channels on your wireless and try it. Also, is there anyway you could try a different wireless router? If FIOS is coming in, there may be maintenance changes in the infrastructure that effect your internet performance.
Aug 14, 2009 | Westell Wirespeed VersaLink...
Verizon DSL Internet connection intermittant Westell 327
verizon dsl westell 7500 internet light goes off 2 to 3 times daily
Jul 11, 2009 | Westell Wirespeed VersaLink...
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
FIOS Internet connectivity problem with Toshiba Satellite 105
Is your laptop running Vista and the desktops running Windows XP or they all running the same software??? Also your problem is the fios router they come set up to be on a automatic channel search so there always searching for the best channel and you probably live in a brick house....Go to the settings for the router you can get to them easy with the software they downloaded to your computer its the fios help icon on your desktop and you can change the routers channel go to 7 or 11... If you have any questions just let me know also please rate me if you get a chance..
Thanks,
Steve
Dec 17, 2008 | Toshiba Satellite A135-S2246 Notebook
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
ACER 5720 WIRELESS CONNECTION PROBLEMS
I have an Acer 5420 which had a persistent disconnection problem after startup, with either the wireless or LAN connection. It appears that the Microsoft network application would startup and make the connection, but seconds later the Acer Enet Management application would start, and its first act would be to disconnect from the Internet. Since the Microsoft network application provides every feature that I want, I choose to disable the Acer Enet Management.
  1. Following up on a hint from on of the posts, I went to Start -> Programs -> Accessories -> Command Prompt.
  2. At the command prompt window, I typed msconfig
  3. About a minute later (after Vista confirmed that it was OK to run this program, the System Configuration window comes up, where I selected the "services" tab
  4. Scrolling down the numerous services, I found "eNet service" and clicked the check mark to disable the service. Hit apply and OK, and restarted my laptop.
  5. The problem went away after that.
Feb 20, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
