Back to:
Tags:
Compaq MV 540  15 in.CRT Conventional Monitor
Monitor problem
posted by trak on May 19, 2006
sir,i have a compaq mv540 monitor.for the last 9 months i am facing a problem in my monitor.some red thin lines (left to right of the screen)always appearing through out the screen.sometimes it disapear,but for a while.what should i do?
------------------------.lines are like this.but i am able to see everything on my monitor not easily.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 23, 2006
FixYa! (100)
silly girl
Rank:Wiz Wiz
Rating: 81%, 3300 votes
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
May need to check the caps in the G-2 supply circuit. Also you may have a CRT going flakey. Just a slight G2 level adjustment may suffice also.
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on monitor problem:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Compaq MV 540 (White) 15 in.CRT...
HI all im new here so here it is... I have this compaq...
problem:- OSD shows Brightness lavel=0 + Contrast lavel=...
my MV540 doesn't give display but it's power supply is...
I want the EHT specification for Compaq Model-GD-501L
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
