Question about Powerware Best Power Best 610 3kVA UPS System
UPS cooling fan replacements (9120: 3KVA)
How long will a stock UPS fan last? What is the best replacement should I use? I need a UPS replacement fan that would last at least 2 years.
  • 64 Answers
If I were you, I would post a question, does anyone have a bad 9120 power ware, that has a fan?
I don't have one.
Posted on Sep 08, 2009
  • StorminP
    StorminP Sep 08, 2009
    I don't have one.
    New Friend:
  • 25 Answers
Call powerware
Posted on Jul 11, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
Posted on May 27, 2010
Run ups without cooling fan
You give little information, can you tell us more?
If the UPS is in a sufficiently cold room it can last without a fan.
But better is if you use a UPS Line Interactive mode fashion.
It is quiet until it starts working.
May 10, 2014 | Computers & Internet
Can I replace the fan in a live powerware 9120?
hey dude your problem is so simple..below are my solutions.
if you already secured the fans for the replacement then its easy for you to do it, try to totally shut down your UPS removing the input and battery supply. avoid replacing the fans with power, its to dangerous. it consist of almost 400VDC inside in it.
call me if you want +63923 3024 585
Jul 11, 2013 | Powerware 9120 UPS System
Geting erro of 59.00 in 4250 printer
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
Fan fault 007
Most likely, you have a faulty fan. The best thing to do is to get a replacement fan and install it. With UPS Systems such as these, the fan is usually user serviceable. Consult your manual for more information.
Mar 02, 2011 | MGE Pulsar M RT 2200VA 3U UPS Hotswap IEC...
I have a caravell ice cream display chest freezer Model # 206-995 S/N 99500317 MFG # ast-30 It has a 3blade fan cooling the motor and fan is very noisey i lube it it s good for while then acts...
You can get that fan motor at most commercial refrigeration supply houses or try Graingers. It might be best to bring the old motor with you.
Jan 18, 2011 | Refrigerators
Hi, Eaton bought Powerware in 2004 and assumed the service for Best Power products. Here is the URL for legacy UPS products like the Unity/I: You'll need to scroll down to the very end of the UPS section. In regards to parts and service, here is the contact info:
Toll Free: 1 800 843 9433
International: +1 919 871 1800
Oct 29, 2010 | Powerware Best Power Unity/I Three-Phase...
The cooling fan is probably not working. Unit will overheat. Check the fan to see if it run continuously with no scraping noise with the UPS turned "ON". If the fan does not run, open the case and replace the fan.
Jan 19, 2010 | Powerware 9120 UPS System
Matrix 3000 "bottom fan fail" need a replacement fan. APC said they don't have in stock and is discontinued.
The APC Matrix-UPS 3000 Isolation Unit IU bottom fan APC part number appears to be 490-0006-A. There are three OEM parts that APC appears to have used:
NMB Technologies 4715KL-05W-B30-P00
Japan Servo CNDC24B7-34
Sunon KDE2412PMB1-6A
But any fan that has the following specs should work:
119mm x 119mm x 38mm, plastic (black) 94V-0, ball bearing, 2-wire, 24 VDC (9.0V min, 10V to 27.6V), 2800 RPM, 80 CFM min, 41 dbA max
Nov 17, 2009 | APC - UPS - Matix/Symmetra Enterprise UPS...
I need a replacement cooling fan for my smart ups 1400. It sounds like a freight train under my desk, and I cannot go buy one off the shelf.
well it could be your fan is dirty that why it makin lot of noise the problem why the ups i quite runnig the fan it becoz it try to cool down the temperture.. as i know your ups i puttin under the desk there not much ventiltation and the floor is dusty.. to be right you hav to place somewhere that is cool and more ventilation.. so the ups won't always be makin sound.. well replace a cooler fan would cost u much and also even u replace the fan it matter of time when your ups trap more dust and evently the ups might givin noise plus your ups might hitting not juz the fan it might be you hardware havin the problem or the battery is easy spoil within 2 years time or less
Mar 21, 2009 | APC Smart-UPS 1400BX (SU1400R2BX120-TU)...
PS2 Cooling Fan not spinning
well could just be shot fans are not suppose to last forever the best thing to do would be replace the fan, make sure that the fan is not plugged up with anything and it has free movement when spinning if it struggles any then its seized up which would have to be replaced measure the fan and take a look on ebay for a replacement fan of that size but if you search for ps2 fan replacement then chances are that it will cost alot more.
if you need help finding a replacement let me know im more then willing to help out.
good luck
Oct 03, 2008 | Sony PlayStation 2 (PS2) Console
Powerware Best Power Best 610 3kVA UPS System Logo
751 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
