Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2060
I have a Bosch Maxx WFL 2060. But the water input pipes have been disconnected. I can't see any mark to say which is hot water intake, and which is clod water intake. Please can you tell me which way round they should be connected ... is hot or cold pipe connected at the top?
    President:
  • 1,462 Answers
Connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Posted on Sep 13, 2008
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Maxx 2260
I fixed a y joint to the cold water outlet and fed ito both hot and cold on the machine
tks
Sam
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
994 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
