Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
Problem with recorded playback
Almost all the shows that I have recorded show recording for the correct time. but as soon as i start watching it the digital picture is constantly crackling and has pixelation and distortion and suddenly stops and shows 0 minutes left. i often get a window that shows recording lost due to signal loss... sometimes that does not appear but the same problem occurs. While watching live i don't seem to have pixelation distortion problems. I do watch and record almost 8hours minimum daily and have used this 625 for 18 months approx. it was a refurb piece to begin with.Do you think it could be a problem with the hard drive or the cables?
  • 374 Answers
It is possible that during a set time of day this problem can occur due to aged hardware such as a barrel or the LNB becoming overheated during that time of the day. If you are home during that timeframe and the weather is consistent and the problem does not exist then I would order a replacement receiver.Dish has some new receivers that allow one to use an external hard drive to increase record capacity as well however they are HD receivers. Currently Dish has a shortage due to production in the 625 model and you may be able to get a 722 rx with 300hrs of record time and external hard drive capability at no additional cost to you do to inventory shortages. If you do opt to get a new rx and get an HD model Dish shoud waive the HD fee for not having HD programming due to this. The key to getting this free upgrade if you will is not to ask for the 722. Let Dish's inventory dictate that unless you just want to upgrade your system in which case ther may or may not be additional charges. Hope this helps you out.
Posted on Sep 23, 2008
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
Dish changing channel to new recording while watching *pre-recorded* program
rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at thomas.faust@dishnetwork.com, and I can assist you further!
Tommy Faust
DISH Internet Response Team
Jan 23, 2012 | DISH Network 54 1 Ir Vip 622 722 Dvr...
I have a Vivicam 8025 and I want to watch videos that I recorded
Once you've got the video preview on the screen, start the playback by pressing the shutter release button.
Mar 18, 2010 | Vivitar ViviCam 8025 Digital Camera
After a timed recording the DVD is showing blank
Try to scan the DVD data into your PC using the trial version of TMPGEnc v4.0 Xpress if this can't find structure data then the recorder must have set the leadin data to show blank.
Nov 13, 2009 | Philips DVDR3380/05 DVD Recorder
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Is it possible to record one show, while watching another ??
You need to put a cable splitter on the cable. One side goes to the TV. The other side goes to the recorder. The output of the recorder goes to one of the alternate inputs on the TV. Set the recorder for whatever channel you want to record using its internal tuner. Use the TV tuner to watch a show live. Later, set the TV input to whatever you connected the recorder output to and watch your recording. You will probably need to do this to see the recorder menu to set up the recording.
Mar 10, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dish Network DVR 625 Problem with playback of recorded shows
It sounds as though the hard drive is about to go south on you soon and the receiver is going to need to be replaced however, in the interim you can change the options of the recordings and make it a default so that the recording continues past the end of the show. It is possible that extending this time will allow you to view the portion you want before it skips to the end. In order to do this press the guide button and select a program in the future. On the create timer screen select the option icon. You will now be at the timer options screen you can extend the time the recording will last after the end of the show and when it will begin recording prior to the show. I would also set this as your systems default so that it performs the same way regardless of what you are recording. According to the latest known receiver issues this is not identified as it is a common indication that the hard drive has an error internally. If this works I suggest that you have a replacement sent to you so that you do not lose the use of your DVR un-expectantly.Remember to watch all recorded events prior to replacement as you will lose that info when the receiver is swapped. Thanks for using Fix Ya.
Mar 09, 2009 | DISH Network DVR-625 DTV Receiver /...
Dvr4-alert full screen playback
That's because this is a quad. It compresses all 4 video feeds into 1 file. When you play it back, it decompresses the video and shows you each camera. Playback through this unit is the only way to see 1 camera at a time.
To be able to copy 1 camera shot to a DVD, this is what you need to do: You need to have a TV with Video in and Video out jacks.  Connect the Quad to the TV Video in jack and connect the TV Video out jack to your DVD Video in jack. Playback a single camera shot on the quad to the TV and hit record on your DVD. - The DVD will record whatever is shown on the TV.
Oct 26, 2008 | Home Security
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
209 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
