Question about Sony PlayStation 2 (PS2) Console
Playstation 2 My Playstation 2 will not read disc...what do I do??
Well brntaffy first off a liitle more info is needed. when you say wont read disc have you tried any or all of the media formats the ps2 supports? music cd, dvd movie, ps1 games, ps2 cd, ps2 dvd. If it plays some formats but not others then the cd eye angle alignment is probably not correct. Is your ps2 a slim or the older thick model? if it is a new slim ps2 you can try the top lens instruction below, but if your ps2 is the older thick model, unless you are at least somewhat of a tech savy type you may not want to attemped any of the other stuff at all. regardless it could be any one or a combination of the following:
1. Most commonly the laser lens (or eye) needs to be cleaned.
before trying any of this yourself read everything first and then have a place to work setup.This place should be clean, good bright lighting, with plenty of room, where you won't get disturb before finishing. and oh yeah wash your hands.
top lens: (if you have a thick ps2 model you will need to remove the outer case(be careful of ribbon cable connection for reset and eject button assembly, if you cant figure out how to remove the button assembly,just set the outer case upside down right next to thebottom) and then remove the top plastic cover of the cd/dvd unit) NEVER touch the eye/lens with your finger- you have oils that will cause it to attract dust/dirt. With a q-tip very lightly soaked in isopropyl rubbing alcohol, use as little pressure as possible, using a circular motion either clockwise or counter clockwise (do not change direction), rub the top lens about 20 to 30 complete revolutions then (without the alcohol) repeat the same method using the dry end of the q-tip
I say this again unless you are a some what tech savy type of person you may not want to attemp anything further.
bottom lens: if you are going to try this or anything furthur, PLEASE BEFORE you disassemble anything!, you need to be prepared with a few items. an artists paint brush- as small and very fine bristles as you can find the length of the bristles should be at least a quarter inch or longer. a few small wooden toothpicks, a can of silicone lubricant , q-tips , a fine point sharpie, oh yeah a regular sized phillips screwdriver and a small phillips tech driver , depending on which one of the, 13 or so different, ps2 models you have, you might find a few other small tools that could come in handy (an allen wrench or that just right size flat blade screwdriver, ect.).
okay back to how to clean the bottom lens: you will need to remove the laser eye assembly. to do this the guide bar the laser eye assembly is attached to will need to be removed, first mark the possistion of the cd eye angle adjustment knob(s) with the sharpie there will be 1 or 2 knobs depending on what model you have, the knob(s) control the height of one end of the guide bar(s). This needs to be very accruate so when you reassemble, the cd eye angle alignment is as you found it, because if the angle isn't right you won't be able to play all the formats the ps2 supports. either a flat metal spring or a srew or something similar holding one end of the bar needs to come out. be very careful of the ribbon cable attached to the bottom of the cd eye assembly, if you look at the plastic connector the ribbon goes into, very gently use something small, a sharp toothpic or tiny flat blade tech driver, to release each side of the plastic connector. this will release the ribbon cable. Now that you are holding the laser eye assembly very very carefully using a toothpic to hold the floating eye up enough so you can get access to the second stationary lens undernieth with your paint brush, brush the bottom lens several times to get any dust.
Now put back together . use a fresh q-tip to apply silicone lubricant to to the guide bars and the worm gear. the worm gear is what moves the laser eye assembly back and forth. check the gear grooves for any foreign material dust lent ect. remember to get the alignment knobs back exactly how you marked them. do the top lens: instruction. reassemble dvd top cover and outer case.
Now if you have done everything just how I said and your ps2 is still not reading any format then you have a more serious problem that will take more time to explain than I have right now but if anyone request this or needs more detail in the above I will find time to explain further possible solutions! lol
hope this info is useful!
Posted on Sep 13, 2008
Spindle motor wont spin and lens are clicking ! ps2 slim problem!
seems like you need to go buy a lens cleaner from bestbuy or something. Run it repeatedly untill it works. sometimes it takes a while. But it will work after. please rate@
May 05, 2011 | Sony PlayStation 2 Slimline Console
Disk read error
The 'Disc Read Error' error message, 'Please Insert a Playstation 2 Formatted Disc' error message, or the 'No Data' error message is an indicator by your system that the console is having difficulty reading the game disc. This could be for many reasons; usually this is because the game disc is damaged or unreadable. However, in some situations, this can be a sign of a more serious issue with your Sony PlayStation 2. Try all of the steps listed below to troubleshoot the error:
Check the game disc.
1. If there are any noticeable scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
Note: Do not rub hard and do not rub in a circular motion as this could further damage the game disc.
2. If there aren’t any noticeable scratches or smudges on the surface of the game disc, try using that game disc in another PlayStation 2.
* If the game disc works in another system, this is an indicator that your PlayStation 2 may be damaged. For information on getting your system repaired or replaced, you will want to contact Sony directly for assistance at 1-800-345-SONY.
* If the game disc does not work in another system, this is a good indicator that the disc is damaged or defective. To acquire a replacement game disc, you will want to refer to your manual for warranty information specific to your product.
Some Playstation systems, especially the older models, have trouble reading some newly manufactured Playstation 2 game disks. Sony recommends using their Auto Diagnosis tool ( to resolve this issue.
Apr 05, 2010 | Sony PlayStation 2 (PS2) Console
Playstation 2 reading disc...
time for a new ps2 im araid, you could try to open it up and clean the lazer but these systems are now so cheap it would probably be better to get a new one or a ps3
Mar 17, 2010 | Sony PlayStation 2 (PS2) Console
My playstation 2 consule says to insert a format disc
Sounds to me you got 1. a dirty drive 2. a bad laser optic
try to get a cleaning disk and run it if that does not work replace the drive that is all there is to it. There is no special buttons to push its the drive.
please do leave positve feedback and ratings for your free answer today.
Nov 07, 2009 | Sony PlayStation 2 (PS2) Console
I just got Petz Horsez 2 for playstation 2, only apparently I haven't inserted a playstation disc or a playstation 2 disc. I have a feeling that the game may not work for my type of playstation 2. Is there...
well the playstation 2 isnt reading the disc. most likely there is a small crack or scratch on the disc. try cleaning it with small amounts of water. to much water can permantly damage the disc
Feb 26, 2009 | Ubi Soft Entertainment Petz: Horsez 2
Disc read error
Try cleaning the eye on the disc drive. If that doesnt work You will need a whole new disc drive
Feb 20, 2008 | Sony PlayStation 2 (PS2) Console
Intermittent Disc-reading Error
First try cleaning optical lens ,you have to use dry cotton sworb.If problem persist than you have to change optical lens.
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
My children's playstation did the same thing. I'm not sure if you have the slimline model or not however, I went into the Sony Playstation website under their troubleshooting section:
Take Disc Out
Restart System
In the Menu Press Triangle for the Version Info Screen
Highlight Console option and press triangle
Press x and highlight on press x again
Press o 2 times to go back into the main menu
Insert Disc
Highlight Browser
Press X to Read Disc
This did work for me but I did have to do it twice.
I hope this helps you
Nov 08, 2007 | Sony PlayStation 2 (PS2) Console
Playstation 2 disc reader
Whats the SCPH model number? What appears on screen when you put a disc in? If it can read CD's but not DVD,s then this is a classic laser related problem, Possibly a dirty laser or syptoms of a worn laser that requires replacement.
Sep 20, 2007 | Sony PlayStation 2 (PS2) Console
Playstation 2 not reading disc
Are you using a real game disk or are you using a burned disk? If its burned you need a MOD chip for it. If its real then try to open up the PS2 and try to clean the lens gently with a q-tip. It helped me a couple of times.
Aug 18, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
