Question about RCA D61W20 61" Rear Projection Television
Power buttonlights set do not turn on
Power buttons comes on set do not come on,started by coming on at times,now will not come on
  • cyberbych Sep 19, 2008
    rca d61w20 turned off and won't turn back on the power light just blinks how do I fix it?
  • Anonymous Oct 02, 2008
    SAME
  • RCA Master
  • 5,138 Answers
Repalce 3 capacitors cp150 cp114 cp120 this will FIX TV.2200uf 16v and two 220of 35v. these are on your Deflection board.
Posted on Jan 09, 2009
It wont power up the lock indicator lights blink 1 time the on buttonlight stays on but thats it
Hi Richard, The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 01, 2016 | Computers & Internet
Won't get past start screen when turned on
Try rebooting. Hold the power button till the menu pops up and click restart.
If that doesn't work try Hard reset Turn the unit off. Press and hold both the power button and the volume button at the same time, until the little yellow-green android robot comes on the screen. You can then release the buttons. You will eventually get a menu (this took a while to come up). Use the Volume button to scroll down to "Reset to Factory Standards", and select by pressing the power button. You`ll get a message asking you if you`re sure you want to do this. Use Power button again to select "yes". It will set the unit back to what it was when brand new.
By doing this you be ready to lose your saved data and setting
Oct 26, 2013 | Nextbook Premium Series Next7P12
When my computer goes into sleep mode and the monitor goes off i have to keep turning the monitor on and off by the power button on the monitor to get it to come on. I hear a static sound and the screen...
Assuming you are using a windows operating system, go to the control panel under the start button. Find power settings and turn off hibernation mode. Sleep mode should be ok. Additionally, on the monitor, find the menu button that pulls up the OSD (on screen display) and see if there is a ECO mode or power saver mode and turn it off as well. Good Luck.
Nov 03, 2017 | ViewSonic VG2021m LCD Monitor
Canon error 6c10 keeps coming up on my printer. last time turning if off and wating for the ink to be in position then turning it on and shutting the top worked, but this time nothing is working and i cant...
Hi there they say the new printers same as you got cant be reset it go to be the shop to do this but you can try this, but pleas can you come back let us know if it worked so other can use this trick, Thanks
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
  5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best
Nov 16, 2010 | Office Equipment & Supplies
TV will not come on by remote or power button
There is a problem inside the set. There is nothing that will lock the set up. I would start with the power supply. Thanks
Oct 28, 2009 | RCA 20F514TD 20" TV
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
    This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
    It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
    Jerry G.
    Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    EMERSON-MODEL#VT911OA-W VERSION-C
    If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
    Aug 20, 2007 | Emerson EWF2704 TV
    Toshiba Cinema Series TV won't turn on
    We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
    Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
    RCA D61W20 61" Rear Projection Television Logo
    69 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
