Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Printing It's strange, it's printing photos 1/2 way within the pic. It almost looks like it took the photos and printed them in white and outlined them in the colors they are supposed to be.
    Problem Solver:
  • 19 Answers
There could be a problem with your printhead, try calling tech support at 800.421.6699
Posted on Oct 23, 2008
I had taken pictures at my son's 16th bd party. I had looked at them on the camera throughout the night. I took a picture and tried to look at it and the camera said file error. None of the pictures...
Take no more pics until you've recovered your photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that may help you recover your photos. This article reviews and outlines several of the better ones:
Jul 28, 2011 | Samsung Digimax S700 Digital Camera
How do i only print black n white pics
Hello!1. Please press Ctrl + P after opening your picture.2. Go to Set up/Advance.3. Select your paper.4. Select Gray scale on the top of your paper size.5. Now press print. Your picture will be print with black & white... Good luck
Jun 09, 2011 | Canon iP2700 Inkjet Photo Printer
Blue tint to all my photos
You may have the white balance set to something other than "auto white balance". If the pics look ok on the camera and on your computer, but the prints are blue, I would suspect the printer.
May 13, 2010 | Olympus EVOLT E-500 Digital Camera
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
RE PRINTING OUT AN IMAGE FROM MY BROTHER MFC-215c PRINTER
Neither nor do I press any of these buttons because you can print by help of the photo assistant of windows which will give you a hand.
Simply right click the picture on your pc and click printing. The assistenat will lead you thru the settings. You only have to make sure that your mfc is the chosen as the printer AND you havte to click the printer properties afterwards. The brother printer properties will let you choose the paper size (simply click the offered sizes and have a look at the left side of the window where a small pic can be seen. Beneath the pic you will find the explanation for the choosen setting e. g. borderless/ 4x6 inch etc.) choose the right paper like glossy for photo paper. When done click OK and leave the properties. Click further through the windows assistant and choose the resolution of the picture. Click OK and machine will print the desired pic ;-)
BTW you can do some very smart thing:
print a poster of 2x2 A4 or 3x3 A4 sheets of paper. You can set this size within the printers properties.
Have a look at the manual for further info ;-)
Dec 06, 2007 | Brother MFC 210C All-In-One InkJet Printer
Printing piss in black and white
Look for "Print in greyscale" in the printer driver.
Aug 31, 2007 | HP PSC 1410 All-In-One InkJet Printer
Freezing up cd label print
Do you have the right firmware settings? http://www.crn.com/white-box/188100839;jsessionid=KRPY0I315LR2AQSNDLRSKHSCJUNN2JVN?pgno=1
Apr 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Printing pics goes to blue
Time a replacement me thinks unless your are upto doing a jet cleaning job. take a look at www.fixyourownprinter.com
Apr 04, 2007 | Epson Stylus Color 660 InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
