Question about Fuji FinePix 4700 Zoom Digital Camera
Lens cover stuck
The camera must have been subject to some kind of physical pressure because: The card slot did not open properly, but I have manipulated it back into place and it works now. The flash would not pop up because two plates at the top were slightly overlapping, but I have manipulated them back and it pops up ok. The lens cover won't open when I switch on, and I can't seem to manipulate it at all. I haven't undone any screws. I really would be grateful for suggestions. Thanks David
  • David Cainer May 19, 2006
    Me again.
    There must be something mystical about this website. No sooner had I logged the problem, when I picked up the camera and felt something click inside it. I shook it moderately vigorously and the lens cover opened.
    The camera is now working fine. The only limitations are those of the photographer (me) )-:
    What a strange experience. It's like cosmic ordering!
    On the other hand, if anyone else has had a similar problem, I should be grateful for any tips on how to prevent its recurrence.
    Thanks
    David
jackboy
  • 2985 Answers
SOURCE: camera lens cover wont open
Get onto Sony Tech Support team. This is a camera failure the will honour the warranty here I am sure.
Posted on Jul 06, 2007
Bluebeard
  • 6 Answers
SOURCE: lens cover stuck open, power wont come on
I have been told by a camera mechanic i contacted on line (in America) that there is a fuse within the camera which is very small and soldered onto one of the boards. I was unable to get a precise location and the only details were that this component was either white with black writing or black with white writing.This may have a bearing on your problem.
Dennis
Posted on Nov 26, 2007
SOURCE: Lens shutter stuck
FinePix A500:
had this solution, tried everything.
Eventually i slowly applied pressure on the focas len, and the zoom mechinism, when it was switching off, and it make a click. some sand came out, and the camera started working.
the motor is loud though, i then polished and oiled the zoom lens cases. and ran some more compressed air though.
I mean, a loud zoom motor, or a £100 repair bill?
i'd rather doing it my way. hope this helps
Posted on Apr 18, 2008
SOURCE: Lens cover stays in between, won't open nor close
Had a similar problem once. Fixed it by opening the camera and freeing up the lens cover.
1)Undo 2 screws each side and the base (6 in all) ignore the one on the front edge of the base for now.
2)Separate the base from the case (gently!) don't pull them too far apart, because they're joined by ribbon cables.
3)Then remove the long screw you ignored above, and again carefully separate the front panel.from the body.
4) At this point, you should be able to access the back of the lens cover, and free up the mechanism.
Once that' s done, put it back together, reversing the above sequence. Don't force anything, just make sure they're all lined up and fit before inserting the screws.
good luck.
Posted on Jun 06, 2008
BeckyJonas
SOURCE: finepix z20fd memory card won't load in slot
Have you ever dropped your camera??
If you have , this is why.
No need to buy a new camera just yet.
Try celotaping it in.
My mom had to do this , after it worked fine!
Posted on Dec 27, 2008
The lens is stuck
memory card slot/battery cover was opened with power on.
2) test the battery for full charge, and the same type alkaline
and the same direction.
3) Full charge batteries.
4) clean contacts batteries with c. cleaner
God bless you
Oct 17, 2012 | Nikon D70s Digital Camera
Lens cover stuck
memory card slot/battery cover was open with the POWER ON.
fix it.
God bless you
Sep 27, 2012 | Fuji FinePix Z1 Digital Camera
Canon Si5 Lens Error message. Have tried suggestions on line
Welcome to FixYa.
There where wo reasons why do you receive a "lens error".
1. CF card slot cover or battery cover opened with camera on
2 . CF card slot cover or battery cover opened while camera was recording to CF card
In this case you have to ensure that CF card cover and battery cover is closed while camera is turn on.
You also need to be careful not to block the camera lens when turning on. Lens will have issues while retracting if your hands or even small thing that will block the lens to retrack while in motion of turning on.
Thank you for using FixYa.
Apr 08, 2011 | Cameras
The description said it was an underwater camera but once i took it underwater it turned off and will not turn on.
Welcome to FixYa.
Before using the camera in under water, you have to secure that battery cover,card slot cover snd DC IN terminal cover are completely closed to prvent water from getting inside the camera and damaging it. Please note that the camera accessories are not waterproof.
Yes, Sanyo VPC-WH1 High Definition Camcorder is a waterproof camcorder, however you can not used it in all types of water. Below are the Cautions concerning use in water.
* The waterproof properties of the camera apply to fresh water and saltwater only. They do not apply to cleaning substances, chemicals or water from spas.
* Do not immerse in water at a depth greater that 3.0m (9.84ft)
* Do not subject the camera to high-pressure water.
* Do not immerse in water for longer than 60 minutes.
After 60 min. of use in water, allow it to dry for at least 10 min.
* Do not immerse in water that is warmer than 40 degree C.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover with wet hands.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover on the beach or at the poolside.
* Do not jolt the camera while it is immersed in water. doing so may cause the battery cover, card slot cover or DC IN terminal cover to open.
And one more thing that you have to do is to chaged/replaced the waterproof seals every year with new ones. For replacing the seals, please consult your dealer and take note that there is a fee for replacing the waterproof seals.
I hope this information will give you an idea on how to use your camera under water.
Feel free to send us your comments and suggestions.
Apr 06, 2011 | Sanyo VPC-WH1 High Definition Camcorder
Shutter button will not depress it says that the lens is either locked or not there
Today's digital cameras are smart. They won't operation if the lens cover is in place (or closed), nor if there is no memory card in place. So ...
  1. Check that the lens cover is "open" or removed. (Open and close several times to be sure it's not stuck or jammed.)
  2. Then check that you have a memory card inserted, AND that it is properly formated (that is, that it is prepared to record images; see your instruction manual for details.
I hope this helps.
Apr 05, 2011 | Cameras
The lens cover is stuck partially covering the aperture and I don't know how to open/close or reset it. Can you help please. Thank you. Alexis
Your camera almost certainly has a lens error. This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses (in your case a stuck lens cover which is a less serious variation of the same fault) are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Sep 30, 2010 | Canon PowerShot A710 IS Digital Camera
Hubby put our daughter's Nikon Cool Pix in his pocket, bent over and now the lens cover is stuck partly open, and won't close all the way. The camera says "lens error". I have tried to close and open the...
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
If your camera is still under warranty and has definitely not been subject to misuse then contact Nikon in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Sep 24, 2010 | Nikon COOLPIX L3 Digital Camera
Lens is stuck open while the camera is turned off. Camera will not turn on now and can't get photos off memory card. Any thoughts.
push in on zoom when turning camera on. this is a firmware problem and camera needs to be updated.
Aug 27, 2009 | Samsung L700 Digital Camera
Canon sd850 is lenz cover partialy closed. Turn on says " lenz error. restart camera. Then shuts itself off.
u have see the user guide if its not help then reset your camera on the factory setting
thanx using fixya i hope it can help u
Sep 06, 2008 | Cameras
Error message 5555AAAA-4489-163-062
check if the little metal lens cover is stuck open.  Mine was stuck open, so I just smacked the camera against my hand and the cover popped closed.  Then the camera turned on normally...
Oct 24, 2007 | HP Photosmart R725 Digital Camera
Fuji FinePix 4700 Zoom Digital Camera Logo
296 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
