Laptop audio problem
My laptop acer series 3002Lci has a problem that its sound is not audible...and when it is connected with speakers it produces sound but it is not clear....
i have already installed its audio drivers but still it does nto produce sound..
plz help me out what i have to do???
  • vvk77 Oct 04, 2008
    i have acer travelmate 2410 model last week i had same speaker problem when i install a new software but after i uninstall the problem same conditions. speaker sound not clear and i tested with external speaker working good problems only in laptop speaker.
    give me a solutions.
    vv_kumar77@rediffmail.com 09898471024
  • Victor Castro
    Victor Castro May 11, 2010
    I dont quite know what to tell you without more detail of what you did and which drivers you downloaded and installed!, sounds like the drivers you installed are incorrect or corrupt if you hear sound but not clear but please reclarigy that, thanks.
No sound at all
Try downloading and installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Mar 07, 2011 | Acer Aspire 3002LCi Notebook
About two weeks ago my acer aspire one netbook just stopped producing any sound at all. nothing comes out of the speakers ever. i did clean up the hard drive and delete some thiigs zi thoyght here...
The Acer Aspire One Netbook has a hidden partition containing installation images for doing an operating system recovery to factory default condition and/or application/driver restore (selectable). In Windows...
1. click on the start button, hover over All Programs, then Acer Empowering Technology and
2. click on Acer eRecovery Management and in its pop-up window
3. click on Reinstall applications/drivers and in the ASPIRE Series Software window
4. click on the Contents button and in the subsequent software listing window
5. click on install icon at the right of the row with Class AUDIO and Description Realtek Audio
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
No sound
Here are the tips to fix no sound problem:
1. Double-click the sound icon in the lower-right corner of the desktop. This loads the audio options menu onto the screen. Make sure none of the audio options are set to "Mute." If they are, uncheck the options, and the sound returns.
2. Disconnect any headphones you have connected to the "Line-out" port on the Acer laptop. If headphones or anything else is connected to the line-out, the audio is not going to be produced by the computer's built-in speakers.
3. Connect your computer to a local power source. If the battery is running low, the laptop often stops producing audio as a method to extend the battery life.
4. Download updated drivers for the Acer computer. If the sound drivers are out of date, the audio is not going to project from the speakers properly. Navigate to the Acer website, choose your country of origin, then click "Service and Support." Click "Driver Download" in the left corner of the screen and click the kind of computer you have. Choose the exact make and model of your computer and all of the available drivers are displayed. Click the audio driver and it downloads to your computer. Double-click the downloaded file, then follow the prompts to install the updated driver. Restart the computer and the audio now plays correctly on the system.
Read this article: No sound on Acer Computer
Nov 11, 2010 | Acer Aspire L100 PC Desktop
My new Acer Aspire one D 250 laptop has a very low volume output . All the volume controls are up including wave output but with no success
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
Nov 25, 2009 | Acer Computers & Internet
No sound from my recently bought aspire 3000
dont pay any attention to the windowes incompatability messages, just load the downloaded drivers,,if you need to,,un-install the old ones,,then go into advanced setting for your sound,,and map your device to the correct player,,ie, sound blaster,,Ac97 etc
Jan 17, 2009 | Acer Aspire 3002LCi Notebook
No Sound after newinstallation of Win XP on Acer Aspire 3002
Did you possibly do something to the audio interface, could it be close to the hard drive area? Check any possible connections you might have loosened or became unattached from motherboard. If not then I would say blow it all away try again, if it persists replace audio board.
t
Nov 21, 2008 | Acer Aspire 3002LCi Notebook
My computer has no sound except on the headphones
first of all unplug the jack interconnecting the speakers to the audio source,put the loudness to max,touch the jack with the tip of your finger(any sound?) if no sound produced open the equipment and check tha fuse and the amplifier.Remember if there is audible sound the source is faulty. thanks
Aug 13, 2008 | Computers & Internet
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
