Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Incoming IP FAX Issue with "FK-502 FAX KIT"
Our Company has brought Multifunction Printer Konica minolta C353 with fax kit FK-502 and MK-711 Mount kit. We have an ip fax line and using Cisco ATA converter to connect with analog fax machines. The standalone fax machines are working with ATA device but the particular model doesnot reciving the incoming FAX but can send the fax.
I heard cisco ATA will support the Fax machine with Baud Rate 9600bps or below. How can we customize the baud rate of FK-502? Please assist me to solve the issue
Thanks in advance
Cheers
flopez
  • 161 Answers
SOURCE: Any way to manually LOWER the Fax Connection Baud Rate?
Newer fax technology adjusts transmission speed automatcally, so no adjustment is necesary. therefore, there is no menu option to change it. Your problem resides either on your phone line or the one you are trying to connect to. Call the other people and ask them if thei are receiving without problem. If you are able to transmit elsewhere and the other party is receiving from everywhere, try turning off the ECM option on your unit.
Posted on Nov 01, 2007
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
ayamaya
  • 143 Answers
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Posted on Aug 26, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Pc fax transmission problem for bizhub 750?
The only solution may be a very expensive "Fax server".
You must have the fax kit in order to translate your print file to the fax language.
Is like trying to send an email without a modem, you may have access to a network but cannot talk the language required.
Posted on Feb 17, 2009
Help "Closing" Conveyance Door
Their is a switch letting it know that it is not closed.
find the switch and either adjust it so it closed the contacts ,when the
door is closed,. or temporarily jump it out to confirm that it is the switch. Sometimes switches can be shimmed up with tape etc.
Jun 03, 2014 | Konica Minolta Konica 7020 W/fax Kit...
How do i install a fax card in the bizhub b250
do you fave both the mount kit and the fax kit???????????????? recommend a tech as certain things need to be done in order
Feb 04, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
Cant find where to connect the phone line
what make and model copier? if there is no rj-14 jack(s) on the copier then it does not have the fax option installed. Many models have a fax button but do not come standard with the fax card. Usually an FK-502 or an FK-503 fax system.
Jan 28, 2013 | Konica Minolta Office Equipment & Supplies
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Optional Fax Kit FK-503 Installation
yes there is a manual, but it required certified technician by konica to install this for you or authorized dealer.
Jun 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Install preventive maintenance kit for Konica copier
hi yes U can see konica minolta sit Ucan downlode users and GO
Jun 04, 2009 | Konica Minolta Minolta DI1610FP...
Di2010
A Print Controller can be installed.
Network print kit: NC-4 PCL Print Controller:
http://www.amatteroffax.com/ItemPage.asp?INVID=1047235&CT=1&CRY=%B4o%B8s%E7PQ%5D%60vT%B1%C8%F5%C9%87%BA%D2%B91%98%1FC
or a
Pi3505e Minolta PN:4513-612:
http://www.amatteroffax.com/itempagey_INVID_1047328_d_Minolta-Pi3505e-PostScript-3-+-PCL-Print-Controlle.htm
or you can install both if you wish.
I haven't found any data supporting the addition of a fax expansion kit. These models were before the FK-502 slide in expansions and I believe that's why the also sold the Di-2010f with the fax.
A network fax option, however, is available with the network scan kit.
Fax Kit:
Dec 22, 2007 | Minolta DI-2010F Copier
Print Fax Confirmation
The Bizhub C250 accepts the FK-502 Fax Expansion card like most other Konica Minolta Products so this data is relevant for many models. Below are the step to enable fax confirmation pages:
Press the fax button.
Press the Utility/Counter button.
Touch Administrator Setings.
Enter password (12345678) or (00000000) are the defaults.
Touch OK
Touch Report Settings.
Touch TX Report Settings.
Set TX Report to ON.
Close, OK, and/or Exit all the way out.
Oct 31, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
453 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
