Question about Magellan SporTrak GPS Receiver
Gps malfunction when I turn on gps it says no pos
  • piotr Dec 11, 2007
    I've got exactly the same problem with my Sportrak gps....it reads no pos and refuses to track.
  • 513 Answers
Try updating the firmware. http://www.magellangps.com/support/softwareupdates/SporTrak_BasicStd.asp I heard of the "no pos" message fixed after a firmware update, and also with fresh NimH bats. could be that it's just not getting enough power from the bats to make the connection. Good luck
Posted on May 23, 2006
92 camry. When turn key to shut off engine the key will not go past the ACC pos. Will not go to LOCK pos to remove the key. Have to disconnect the battery to turn key to LOCK pos. What is the fix?
Park shift interlock. A safety device that will only allow the key to be removed when vehicle is in park. It is malfunctioning could be as simple as a cable sticking
Feb 11, 2017 | Toyota Camry Cars & Trucks
2001 chevy tahoe will not start/turn over
First do you mean it wonk crank when you turn the key have you check the security on the truck if it's the security the truck won't crank you can bypass that try cranking it with a wire from the pos of your battery if it cranks Eather a bad switch or the chip on your security system good luck
Sep 23, 2015 | Chevrolet 2001 CHEVROLET TAHOE Chassis...
Hyndai h1 codes p0335 p1131 p0180 p1123 p1120 p0121 p1127 p0110
Wow do You have a bunch of different Sensor and Circuit Problems
0110 Intake Air Temp Circ Malfunction
0121 Throttle Position sensor A Range Problem
0180 Fuel Temperature Sensor A Circuit Malfunction
0335 Crankshaft Pos Sens A Circ Malfunc
1120 Throttl Pos Sensor Circuit
1123 Throt Pos sens Higher then Expected
1127 Exhaust Not Warm Downstream 02 Temp Sensor
1131 Lack of Sig H02S Sens Indicates Running too Lean
Learn more about codes here http://www.troublecodes.net/OBD2/Pcodes/
I would guess with all this You may Have a Connection Problem or a Computer Issue Get the codes reset and monitor as soon as check engine light comes on to see what codes com up first and what codes are pending
Good Luck Rickie
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
May 13, 2014 | 2010 Hyundai H-1 Travel
Took battery out of my 1993 buick riviera,put back in now starts then dies
how did you disconnect the battery, pos first then neg ? or neg first then pos ? try starting it and after started, hold your rpm at 1500, for about two minutes, then if still running, drive it to get to.speeds of 40 for about 15 minutes, this is to relearn if not, disconnect your battery, take the pos and neg cable and touch them together and hold for about a minute, then Connect them back, neg.first.then pos, then follow steps above to.relearn.
Dec 09, 2013 | 1993 Buick Riviera
My rino 110 will not stay on in cold weather, it will turn on but then turn right back off again. What can be done?
Batteries do not fuction well in cold weather. Use a better battery like the lithum or warm up the battery by rubbing back and forth on your pants both sides pos and neg.
-david
Nov 07, 2010 | Garmin Rino 110 GPS Receiver
Can you tell me what codes 54 and 21 are on a 1995 caravan 3.0 please?
Hello..
Code 21: Is an oxygen sensor Code 54: Is a crank positioning sensor.
Hope this helps!
Dec 06, 2009 | 1995 Dodge Caravan
Unit makes sounds but no display
Hi
If unit is as per pic I assume it has external antennae. Ensure the multi pin plug is secure in the rear of the unit and also use a fully charged 12 volt battery, Has it been working before?? Usually a rear plug problem. How old is unit. Just had a another thought, check that the polarity is correct, ie pos wire to RED (Pos) on battery. Very polarity sensitive.
Cheers cbacer
Aug 12, 2009 | Garmin GPSMAP 178C GPS Receiver
Diagram of 36 volt hookup for trolling motor, i have a factory 24 volt wiring in my boat and I need to turn it into a 36 volt please help thank you
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
This is only a solution for 3 battery system.
For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
budman772357@embarqmail.com
Mar 01, 2009 | Minn Kota Boating
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
"NO POS"
Have you gone through the "Initialize" process again? If the memory has been cleared you will need to re-initialize. Refer to page 4 of your manual. Power On > Select Language > "ENTER" > INITIALIZE screen > "ENTER" > Select Region > "ENTER" > Select Area > "ENTER" > Enter Elevation > "ENTER" (if you don't know elevation, press enter) > Enter Time > "ENTER" > Enter Date > "ENTER"
Jul 05, 2007 | Magellan GPS 315 GPS Receiver
Magellan SporTrak GPS Receiver Logo
324 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
