Question about Asko W6461 Front Load Washer
W640T2 (CIRCIUT BOARD)
I have a asko W640T2 thats the model on the invoice 6 years old. There is a short in the washer it keeps on throwing the house earth switch out so I had a look at the circuit board and found some componace were black and mybe burnt can I buy the board with the componance over the net or will I have to have it repaired (This washer is electronic) Hope you can help MANY THANKS
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Posted on Sep 23, 2008
    President:
  • 1,462 Answers
Can't help you a lot with this. you should be able to buy the spare over the net. however be careful, circuit boards often burn out due to an external fault. trace where the burnt items end up on the connectors of the board and trace the wiring to see if you can check if an external component is faulty. i'm in UK not US
Posted on Sep 13, 2008
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My ASko washer machine will not start up, all I hear is a short humm when I press the start button. I took the cover off and noticed the control board has a burned chip on it. There is also a resistor with...
Sounds like the control board is fried. If you have gotten it open here is a link for a new board:
http://www.superiorapplianceparts.com/shop/asko-washer-control-board/?q=/shop/category/washer/asko/
Good luck! And make sure the thing is unplugged before you work on it!
Joseph
Apr 04, 2011 | Asko W6021 Front Load Washer
Throwing the breaker .had the oven for 6 weeks working fine now turned on the upper oven and the breaker threw. the house/wirting is only 10 years old?
You have a problem in the oven not in the house wiring...you probably have a bad element in that oven and it is shorted...this throws that breaker when you turn it on...
heatman101
May 06, 2010 | Whirlpool GBD307PDS Electric Double Oven
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
A 906901 whirlpool washer that won't agitate
Unplug the washer for 10 min. This will reboot the circiut board. Then select one cycle. Too many cycle selections in a short period of time can overwelm the little brain in the curciut board.
Apr 30, 2009 | Whirlpool Washing Machines
ASKO W640T2 (Circuit board)
hi Unlike a toaster, which performs the exact same function over and over, washing machines run through elaborate cycles with multiple settings. The devices that control these cycles can occasionally fail. Here's how to repair some of the common switches and timers.
Servicing the Lid Switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.
Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailed
here. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.
Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Sep 13, 2008 | Asko W6461 Front Load Washer
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Asko W6461 Front Load Washer Logo
293 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
