Question about Olympus Camedia C-5050 Zoom Digital Camera
On/Off Switch Hi My problem with the 5050Z is as follows; When I switch the camera on the lens extends and then retracts but not always. This can carry on until I turn it off. On the odd occasion that this does not happen, should I lightly touch the on/off switch (but not move it) the lens begins to retract and extend again until I turn it off. Has anyone experienced this problem, if so, is there a solution? I've tried removing the batteries for 24 hours to force the camera to fully reset but it didn't help. Thanks Robin
  • yarrl Apr 11, 2008
    I have had the same problem on 2 Olympus c5050 cameras that were bought by my company. They both failed within 2 weeks of each other.
    The symtoms are it turns on then turns itself off and just cycles until you switch it off.
    I have got them both working by spraying contact cleaner and excercising the on off switch (batteries removed). It took about 3 applications to get each camera working but they seem OK for now.
    There is probably a design fault on the switch
    Larry
  • SGS-art Aug 22, 2008
    Forresty -- please see the thoughts about the C-5050 turining itself on and off at the bottom of the main page. I dont want to repeat the whole thing here...
    It's a frustrating situation, isn't it?
    SGS-art
I too have experienced the same situation .... I have THREE C-5050's and "REGULAR" part seems to occure when the camera is overworked, or WARM. Does your camera become warmer is you are shooting many picturees one after the other? When it cools down (black case could add to the scenario), the problem stops.
I have found that over heating occurs from two situations:
1. Taking shots one right after the other, quickly, for a number of shots in very rapid succession
2. leaving the camera sit in the sun
What do you all think about this? Is it of any assistance?
SGS
Posted on Aug 21, 2008
    Novelist:
    Scholar:
  • 117 Answers
I've posted this elsewhere on this site but I can't find a simple way of linking directly to it, so I'll repeat it here: ================================= The powere switch is part of the mode dial assembly. Mode dial repair kits are often listed on eBay. Don't try the repair yourself unless you have some experience in dismantling (and more importantly re-assembling!) modern cameras - although given that getting an "official" repair is probably not economic it may be worth the risk. There are instructions for replacing the dial here http://myolympus.org/5050/modedial/ It's really not that difficult but patience and good eyesight are needed.
Posted on Sep 16, 2007
    Scholar:
  • 117 Answers
Hi Robin, That is a great camera. It sounds like there is a problem that would require a return, for repair, or a replacement. There is a short in or very near the on/off switch. If you cannot return it, and it really bothers you, there are a lot of camera shops that could fix it for you. Or, if it is not much of a nuisance, leave it be, it may last for years. Sorry I couldn't be any more help. nightdiver
Posted on May 19, 2006
SOURCE:
I have a zooming problem on my Olympus Camedia C-700 Ultra, can you help?
It sounds like some part of the power zoom mechanism has failed. It could be repairable but with the age of the camera I doubt it would be worth it- something else may fail and a newer camera would also provide improved image quality.
Jan 27, 2015 | Olympus Cameras
Lens error restart
Normally just recharging / replacing the camera battery will allow the lens to retract. If not. Switch on the camera and GENTLY apply pressure to the lens at the same time. If not, im afraid it's off to the camera repair shop.
Jul 23, 2014 | Canon PowerShot G11 Digital Camera
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Please help - my lens will not come out, once I switch on my camera. It comes up with an E18 message Vicky
E18 error means that the lens mechanism is jammed and the lens cannot extend/retract.
Follow the steps provided below to solve this problem.
Remove the batteries from the camera, wait for 10 minutes, then put them back in and turn the camera on.If this does not work then try the compressed air. With a fine tip blow off gun and dry compressed air set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function as fine.If this also does not work then you need to force the lens out .
Hope this helps.
Thanks for using Fixya.
Jan 31, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Hi-- my canon SX110 won't switch on properly. it keeps telling me there's a lens error and to restart. when this has happened in the past, i've just switched it off and then on again and it's worked. not...
Try removing and replacing batteries to reset the camera. Ensure that batteries are fully charged.
If that does not clear the problem, then the lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 16, 2009 | Canon PowerShot SX110 IS Digital Camera
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
Olympus Camedia C5050 Zoom
The unusual beeps usually occur when the lens cannot be extended or retracted, often due to dirt in the gearing or the lens cap being left on.
Try using canned air to blow around the outside of the extension cylinder, and, putting a fresh set of batteries in the camera (it probably got stuck on since it couldn't fully retract the lens and didn't complete the shutdown).
If that doesn't work, try taking it to a camera store with repair technicians and having them take apart and clean the lens extension/retraction mechanism.
Aug 19, 2007 | Olympus Camedia C-350 Digital Camera
After switching on - the lens extends and retracts repeatedly
I had the same issue and thought me Ebay camera was trash. I put the batteries back on the charger over night and it worked properly in the morning. Looked to be a low power issue, but my lens did look like it was all cocked, grinding and stalling. perhaps the camera reset itself with no batteries in it for a few hours> I was very relieved.
Jun 13, 2006 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus Camedia C-5050 Zoom Digital Camera Logo
190 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
