Question about MSI KM4M-V KM400 SocketA 333FSB 2DDR Aud+Vdo+Lan 3PCI+AGP8X SATA (I7061020)
Adding ram I have a MSI KM4M-V 333fsb,but it has only 256 ddr ram. Can I put in i gig ddr ram chip to make it run faster or will the speed cook my motherboard?
  • 781 Answers
Supported RAM TechnologyDDR SDRAMRAM Installed ( Max )0 MB / 2 GB (max)Supported RAM SpeedPC2100, PC1600, PC2700The above is the specification for RAM for your M/board
It can take up to 2Gb ram 2 X 1GB sticks you may have to change BIOS settings aand your computer will definitely run fasterPlease give me a FIXYA
Posted on Sep 20, 2008
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
Why my mother boarb ASUS P5P800S did not run for DDR 400 I want computer more faster my DDR I used now is only 256
hi, actually that 400 is not the ram speed. its the ram frequency. DDR ram comes in 3 types of frequency. one is 333hz and another is 400hz. normally people use 400hz. you should not put two kinds of RAM modules with different frequency at same time.
make sure. all the rams you are using are of same speed and same frequency. example use 256 of 400hz with 256 of 400hz. this must help. else revert back to us. thank you sweet rascal
Oct 18, 2009 | ASUS P5P800S Motherboard
Upgrading memory
hi If you go to www.crucial.com they will scan your pc & tell you what rams youhave & what you need. then buy from wherever. hope this helps blue51
Apr 14, 2009 | Dell Dimension 4600 PC Desktop
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Memory Problems (MSI KM4M-V Motherboard)
if you know the make and model number of the memory sticks you will need to contact the manufacturer to find the voltage specifications so you can adjust the bios accordingly. Or do a google search with the model number and make of the memory stick for voltage details
Jan 14, 2009 | MSI KM4M-L Motherboard
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Wont recognize additional ram
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Dec 20, 2007 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computers & Internet Logo
247 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
