The ASKO W640T2 keeps throwing the earth switch I had a look at the circuit board and it cooked a couple of the componance on the board is it better to by a new one or can it be repaired. Can I buy a new board off the net and where If you help many Thanks GARY (AUSTRALIA)
hi
Unlike a toaster, which performs the exact same function over and over, washing machines run through elaborate cycles with multiple settings. The devices that control these cycles can occasionally fail. Here's how to repair some of the common switches and timers. Servicing the Lid Switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
Step 1: Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
Step 2: If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment.
Step 3: Test the switch with a VOM set to the RX1 scale; procedures for using the VOM are detailedhere. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced.
Step 4: If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected. Step 5: If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
Was this helpful?
Yes
No
Popular Solutions for Asko W6461 Front Load Washer
Not quite sure of the Asko model (just moved in) the washer won't start - comes up with symbol (door...
(More)(More)
Not quite sure of the Asko model (just moved in) the washer won't start - comes up with symbol (door not closed) even though it is - I can't wait to use it. Thanks.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
need wiring diagram 4 asko w6461......tech removed module and iam replacing but dont know where 2...
(More)(More)
need wiring diagram 4 asko w6461......tech removed module and iam replacing but dont know where 2 connect wires
Posted. Thank You!
I have an F2 display on my asko 6461 washing machine. what does it mean, and is there something I...
(More)(More)
I have an F2 display on my asko 6461 washing machine. what does it mean, and is there something I can do to fix it
Posted. Thank You!
my washer keeps flashing F2 and i can't get the door to open. i've turned off and on but the F2...
(More)(More)
my washer keeps flashing F2 and i can't get the door to open. i've turned off and on but the F2 keeps appearing
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
