Question about MSI K8N Neo4-F Motherboard
Hooking my Neo4 mobo back up.
I am attempting to re-wire my mobo because I got a new one and didn't realize it wasn't compatible with my old ram until it was too late. Needless to say I am trying to restore things back to the way they were. I have everything hooked up except a few last wires. These are:
Reset SW (Two wires: Blue and White)
Power SW (Two wires: Orange and White)
H.D.D. LED (Two wires: Red and White)
+P LED (Single Green Wire)
-P LED (Single White Wire)
I found the online version of the manual, but the way it describes the pins doesn't match up with what I see. It gives things such as Power SW P (positive I'm assuming) and Power SW N, but the two wires are joined into one 2 pin connection. I don't know which is positive and which is negative. Same for the Reset SW and HDD LED.
I also have an odd little piece I disconnected and can't remember where it goes. It looks like a 4 pin connection, but with wires only in the 2 outside slots. On the end of the piece is a black cylinder where the wires meet up.
    President:
  • 2,351 Answers
Hi weeman105, case wire colors do vary from case to case. The most common case wire colors for negative are "white & black". All other colors like blue, green, red orange are most commonly "positive". The four pin connector with only the ends with wires is the internal speaker. Most boards use one set of pins where you hook everything up. The MSI K8N Neo4-F uses two separate motherboard pins, Front Panel Connectors: JFP1 & JFP2 as shown on the top page 2-19. Now that you know what color is positive & which is negative things should work out just fine.
Downloaded manual from MSI link: http://global.msi.com.tw/index.php?func=downloadfile&dno=4117&type=manual
If you run into any other troubles, just post & we'll go from there.
Good luck weeman105!
Mike
Posted on Sep 13, 2008
Power button does not light, fans run but computer does not send signal to monitor. Replaced power supply, no change. Put in new graphics card, still does not generate video that would allow me to change...
no HP PC stated just a MOBO. must we guess?
no the power button is just 2 wires, a digital line and ground
it must be plugged in to the correct MOBO jack.
in fact i can turn it on with a simple jumper wire, there.
i guess you found the board, in garage sale, just tossed in a box?
if the local vga jack and added in VGA card both fail then its a mobo issue.
im googling for you.
lets see what POPS
Compaq Brio ATX PGA370 New D7580-60003 *
This motherboard is only compatible with Celeron 400 CPUs
With integrated SiS Super AGP graphics controller?
takes 1 good RAM stick.
if the fan fails to stay on, that means the PSU sees errors.
mostly sees shorts on MOBO(remove things to find it)
that one old mobo is rare, now.
is the coin cell at 3vdc, or below 2.9v, if yes, needs new one.
HP has zero data (information) on this old mobo or the COMPAQ BRIO anything.
https://www.youtube.com/watch?v=3at_Ev2kOoI
Aug 13, 2017 | HP (D7580-60003) Motherboard
Mobo Compatibility and tech/spec variations
All Asus P5GC-MX/1333 mobos are "X-series" boards.
If you put higher speed ram on that mobo, it will just run the ram at lower speeds.
The board will not take 1333 speed DDR3, because it is only DDR2 compatible.
OVerclocking is complicated and risky, here is neither the place to teach or learn overclocking.
Some newer core 2 chips will automatically overclock, when all but 1 core is in hibernation (which will never happen if you are using vista). Other than that overclocking involves setting the bios to increase the memory buss speed, as well as slightly increasing the cpu and ram voltages as needed for stability. There is a great risk associated with manually overclocking and adjusting voltages, and should not be attempted by beginners on machines they value.
Dec 27, 2009 | ASUS P5GC-MX/1333 Motherboard
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
Sounds as though your new RAM may not be compatible with the ECS.This is most certainly the case if the system boots correctly with the old RAM back in place.You may need to check the specs for this mobo on the EliteGroup website to find out what RAM is compatible.
Nov 07, 2009 | EliteGroup P4VMM2 Motherboard
MSI K8N Neo4-F Motherboard power on but ,not post
At this point I would try another processor and if you still can't get video with another known good working processor then that means the motherboard is bad. Also check for puffy capacitors, that would cause the motherboard not to post as well. If all the capacitors has flat heads on them then the motherboard is still bad.
Jun 12, 2009 | MSI K8N Neo4-F Motherboard
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
It says board can take 4 gig of memory but back slots 2 big
If your MoBo supports 4 Gigs, Vista 32 bit will only utilize approximately 3.48GB, and XP 32 bit will only use 2GB, so unless you are running Vista 64 bit (which will use up to 8GB, if your MoBo will?), the OS isn't going to see but 2 to 3+ depending on which version of windows you're running,
As for the slots being too big, you are probably attempting to install the wrong RAM for your MoBo. Compare the RAM in question with what the MoBo manufacturer says is compatible.
Good luck, and I hope I helped you.
Apr 10, 2008 | Computers & Internet
Starting computer
Your power and data system need inspection inside the MoBo. Hardware problems produce warning beeps, especially RAM and VIDEO. Check these first to make sure they are in slots.
Does it show anything on the screen while it's beeping??????
Please provide more information and come back
Feb 19, 2008 | MSI K8N Neo4-F Motherboard
MSI K8N Neo4-F Motherboard Logo
216 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
