Question about HP Compaq WF1907 Monitor
1907 Monitor Stand
I have just purchased the HP monitor. As I took it out the box and tried to straighten the stand to set up the monitor, the stand would not move and appeared to be stuck. The quick setup instruction illustrate that the stand should rotate out but I can't get it to move. Is there a release I don't see or is my monitor stand defective.
  • 1 more comment
  • kwm34 Sep 14, 2008
    Thanks for the comment. I found it helpful to attach the base bracket on first and then straighten by bending the monitor into position.
  • antheat17 Dec 12, 2008
    i have the same problem and when i put on the base and try to straighten it it still had the same problem
  • elund Feb 02, 2009
    Same Problem - and really don't want t crack the screen/force the hinge to straighten. Am I doing it in reverse or something?
For the hp x1907 we purchased recently there is no release it is just really hard to straighten, it has to be tight because you wouldn't want a wobbly stand
Posted on Sep 14, 2008
Can we remove stand from monitor HP 2010i
Dear yes you can remove stand of HP monitor with the unlock behind the monitor near stand neck.
Thanks
Firoz Ali
Apr 28, 2014 | Computers & Internet
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
In moving to a new apartment I flattened the neck of the circular stand with the monitor LG flatiron slim 19" into the box. Went very easily. Now when I put up my computer the stand of the monitor...
On my HP monitor on the stand, I have a locking mechanism that doesn't allow the display to be raised. I need to press a button on the stand while pushing down the display, then the button is possible to be pressed down. then while holding it down, I can pull the display upwards as much as it comes.
the stand locks in my case when pushed all the way in.
Maybe this is the same thing on yours? Maybe not?
Oct 03, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Monitor going to sleep
Try checking your Windows settings by right-clicking on the Windows desktop, then properties. You will be able to see Display Properties dialog box. Click on ScreenSaver, then click on Power Saving.
Look for "Turn off Monitor.." you can set it to "Never".
Feb 18, 2009 | HP Compaq FP5315 15" LCD Monitor
Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Jan 18, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hp monitor 1907w. Stand makes monitor bend over. how to straighten?
Hit the auto adjust button in the monitor
Please Don't Forget To Rate "FIXYA" Me For The Help
Dec 21, 2008 | HP Compaq WF1907 Monitor
Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Jan 30, 2008 | HP Compaq WF1907 Monitor
Monitor tilts down
Is there a bolt to tighten down in the back?
Aug 29, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
HP Compaq WF1907 Monitor Logo
439 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
