Question about Ricoh Aficio CL2000N Laser Printer
Error message We have 5 ricoh aficio CL2000N and one of them keeps coming up with the following error "SC 554" supposedly it is the heating roller's temperature that is a bit too low. We are now sure how to fix this, it will print a cople of pages and then nothing, please help Tony Ramos Kewanee School District # 229 IT Department
  • 513 Answers
Not sure if your printer is the same, but one ricoh I saw had an energy saving setting, that's meant to play with the warm up time of the heating roller. If you still have the manual and can find the access to such settings, you could try it with each one of the settings, to see if it fixes the problem. It's possible that with energy saving turned off your problem will be solved, which isn't a bad idea for a frequently used school machine. If it does solve it, you could ask the users to make sure the machine is turned off when it's not being used for a long period of time. Good luck
Posted on May 23, 2006
  • kiki1912 Sep 27, 2010
    I had this same error message on a ricoh unit at work. I pulled the fusers out and the they had toner buildup on them. I vacuumed out the unit and fusers and it was fine once I turned it back on. I would suggest a good cleaning on the inside of the unit.
SOURCE:
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
I have a Ricoh Aficio CL2000N Laser Printer and it is displaying an error message, which reads, SC 846 Power off on. What can I do to resolve the problem?
SC846 is not a code listed in the service manual... are you sure you are reading it right?
Try turning the machine off, unplugging it for 30 seconds, and turning it back on. Any luck?
Aug 23, 2010 | Ricoh Aficio CL2000N Laser Printer
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
My Ricoh CL2000n is getting the "SC 554" message and the power saving mode is turned off. Do you have any recommendations?
That is a fuser code and will not go away by turning the power off and on. The code needs to be reset in the service mode, and maybe a new fuser.
Nov 25, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Service Call SC 553 on Ricoh Aficio SP C811DN Printer.
No.
Type
Details (Symptom, Possible Cause, Troubleshooting Procedures)
553
A
Heating roller overheat (software error)
The detected heating roller temperature stays at 230°C or more for 1 second.
• Defective PSU
• Defective lOB
• Defective EGB
1. Replace the PSU.
2. Replace the lOB.
3. Replace the EGB.
This is the simptoms of the service manual , you should check that your power output is stable and double check if there is not anything like paper stuck some were in the fuzing unit wich could also cause the fuzer to over heat
Nov 11, 2007 | Ricoh Aficio SP C811DN-DL Printer
Error Code
HAD SAME PROB I WORK FOR RICOH DIRECT SERVICE 670 IS ENGINE CONTROL BOARD OK....
Feb 16, 2007 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio CL2000N Laser Printer Logo
2,294 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
