Question about Samsung Blackjack SGH-I607 Smartphone
All multimedia stopped working!!!
All Audio and video(including preloaded ring tones and msg tones) will not work. Wont even open... Just started to give me error msg "file is corrupt or unavailable"... any ideas
  • Anonymous Sep 23, 2008
    same deal happened to me
  • jacko039 Oct 11, 2008
    I had this same problem, and found the only solution was to sync everything to ur pc or save to a microsd card and do a master reset... It takes some time, and is a pain, but it worked just fine for me..try that and see...
I have a blackjack 2 that is only a couple weeks old, and when i try to go into the settings to change the ring tone for text messaging.. i get error: the settings cannot be opened. please help.
Posted on Oct 11, 2008
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
Audio folder but it wont let me sat them as ring tones
cuz they r too big for a ringtone. if its bigger than a certain size it wont let u set it as a ringtone
Aug 28, 2009 | Pantech Matrix Cell Phone
How to send the ring tones on the mobile
When you go to new message choice and click it choose the TXT Msg option and then add your contact person that you want to send this ring tone to. Then it should say on the sides on the screen Abc and Options you will choose Options. Then choose the option that says Add Sound. After you have clicked on that there should be two options, 1.Preloaded or 2.Downloaded. You should probably choose Downloaded, but if it's not there then Preloaded and then click the ringtone and it should take you back to the screen were you can write. Right there your ring tone is added and you can send it to who ever you want.
Apr 10, 2009 | D3 Publisher Simple 2000 Vol.29: The Nenai...
Vista and yahoo voice compatability
Download the newest version of messenger, It includes the codec you need to enable voice
Mar 18, 2009 | HP Computers & Internet
How do I get a louder ring on my blackberry 8700
From profile on desktop choose Loud and activate - The megaoohone logo at the top of the homepage should now have a red outline.
Jan 23, 2009 | RIM BlackBerry 8700g Smartphone
No message tone
doesit work with a standard msg tone if not ur phones its ready to get urself a new 1 i had same problem with an old phone
Sep 11, 2008 | Nokia N70 Cellular Phone
How to set downloaded ringtone as a ringtone
Go Multimedia/Sounds then select wherever your ringtone is, either:
Preloaded & downloaded (it shoud be here, if not)
Additional storage device
When you see your tone in the list, press the centre key. The first option is "Apply As Ring Tone"
Let me know how you get on.
Jan 09, 2008 | Motorola Mobility W375 Cellular Phone
Data cable
the 8910 doesn't support ring tone programming. you are stuck with the preloaded ring tones. even with the data cable.
Dec 20, 2007 | Audiovox 8910 Cellular Phone
Ring Tones
Try This:
Open the message. Than hit the menus button. Find save items and click it. It should than ask you to save what? select file and save the ring tone to your phone.
To send a ringtone.
Open Sounds, find the one you want to send, click menu, than send in message.
Dec 10, 2007 | Motorola Mobility RAZR V3
Samsung Blackjack SGH-I607 Smartphone Logo
174 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
