Kenmore Washing Machine Model #110.91551200
The machine will fill and agitate on all 3 settings. After the agitation stops, nothing happens. No motors are running, it just won't drain or do anything. I've tried running through all 3 settings (Normal, Heavy Duty, PermaPress) and setting it to Rinse or Spin, but to no avail. It will only agitate at this point. Now I'm stuck with a load of clothes that I can't drain. Any help will be appreciated.
  • J. McNaughton Sep 18, 2008
    It was indeed the lid switch. We're in business again! Thanks so much.
  • 5,911 Answers
The symptoms you are describing are a caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 11 (part #285671) and the lid strike is item number 20 (part #350733).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
Posted on Sep 13, 2008
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
May 03, 2010 | Kenmore Washing Machines
Washing machine filled but wont agitate after the fill,it humms
Maybe the agitator isnt agitated enough.....yell at it for a bit...see what happens....if it that dont make it spin poor a lil rum in the tub....
Mar 01, 2010 | Whirlpool Washing Machines
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Jan 21, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
292 people viewed this question
Top Washing Machines Experts
