Question about Gateway Computers & Internet
Reloading os - Gateway Computers & Internet
    Novelist:
  • 116 Answers
If you're trying to reinstall windows? Pop in your windows CD or recovery disc and just follow the directions. The installation process is very easy. :)
Posted on Sep 13, 2008
After when i reset HP Mini 110-3735dx the system no more found it( an operating system wasn t found)
redux 1
NO OS STATED before the ***** of pc. W7 was new
is it w8, w8.1 or W10 (slammed )
F11 dead. got you.
that means (list)
the hdd is bad.
or
infected with virus (damaged F11 partitions recovery)
or
some one put a Microsoft disk (not HP)
and did a install not using HP media.
bam
I call it slammed.
http://pcdied.com/XP-sux-sg.html#slammed
if I boot that PC and it run under say
knoppix 7 perfectly , then the PC is ok
if the disk test passes, then the HDD is ok
and only the partition (HP restore) is damaged or missing on said HDD.
is it missing,did you look ? we use that same linux disk to LOOK... to see
the knoppix disk tests are here. under bad hdd.
http://pcdied.com/brick-dead.html
http://pcdied.com/brick-dead.html#Knoppix
the order is this, flow)
1: is the PC ok? battery ok, coin cell ok?
2: test PC with Knoppix 7
is pc ok?
3: test PC HDD with Knoppix disk tests.
looking at SMART data first, is now out of spare clusters and lots of dead clusters growing,
yes, bad hDD, or even its dead, then we run the full hDD test using Knoppix boot stick,
4: ok hdd seems ok, i look at the Hp recover partition. using same knoppix.
is it missing, or obviously damaged or files missing?
then it was slammed.
5: we then install fresh what ever OS you want.
how to do that and choices are many.
best is the HP media kit , to make it like new.
other use other ways and take days to find all the missing pieces, (humpty-dumptied)
I can do that latter my self ,done so 1000s of times.
(I go to HP and see what is there and get all these files)
the PC came with W7, if your PC was not w7 now
that means you slammed the PC, with W10.
you have yet to say what OS you ran before it died.
if w7 great, if w10, ouch..
https://support.hp.com/us-en/drivers/selfservice/hp-mini-110-3700-pc-series/5082187/model/5111936
if you have damaged F11,
install w7 any why you can, (most ways fail)
a real MS disk from MS actual will work to a POINT.
the MS disk will miss many HP drivers. and all apps
so go to the above link and get them all
warning HP only SUPPORTS W7 on this PC> period.
Aug 15, 2017 | HP Computers & Internet
How can change Vostro 3300 32bit- 64bit
You'll have to reload from scratch (not upgrade) a 64-bit operating system, such as Windows 7. Make sure the reason you think you need 64 bits is worth the time and effort of:
1. Saving ALL your Data Files before you start, perhaps to an external HDD, a USB flash drive or a network drive.
2. Saving backups of all your applications -- electronic banking, Email, Address books, etc. (Outlook data files)
3. Reformatting and reloading a new OS (you'll probably have to buy it).
4. Reloading all your applications (make sure you have ************, serial numbers, etc.
Unless you have a new mission-critical app that requires a 64-bit OS, I'm not sure you'll be happy with the outcome. The PC probably won't perform any better than it does now.
Apr 02, 2017 | Computers & Internet
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Bb 8310 has white screen and error 523 message on it
    Thank you for using fixYa
    There is a problem with the phone OS
    the most efficient fix would be to reload your OS
    If possible do a back up of your phone and then reload the OS
    here is a link with information on how to load the OS
    http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
    Hope the information is helpful
    Jul 14, 2011 | RIM BlackBerry Curve 8310 Smartphone
    Uncaught exception: index 13>=13 app
    How To Reload Your Operating System
    Here is a KB that discusses that error:
    • KB16471 BlackBerry Desktop Software prompts that an Internet connection is required to configure synchronization
    Hopefully it contains something useful!
    As an alternate method, from a PC, you can install any OS package to a BB via this procedure:
    Note that while written for "reload" and the Storm, it can be used to upgrade, downgrade, or reload any BB device model -- it all depends on the OS package you download and install to your PC. You can even use a different carriers OS package by simply inserting, between steps 1 and 2, the deletion, on your PC, of a file named VENDOR.XML. Be sure that you remove, from your PC, any other BB device OS packages as having more than one installed to the PC can cause conflicts with this procedure.
    If you are on MAC, you are limited to only your carriers sanctioned OS packages...but can still use any levels that they currently sanction. See this procedure:
    • KB19915How to perform a clean reload of BlackBerry smartphone application software using BlackBerry Desktop Software
    Apr 08, 2011 | RIM BlackBerry Curve 8520 Smartphone
    App error 205
    Unfortunately you are going to have to reload the OS. You can find the instructions on how to reload the OS from :-
    You'll also need to download a new version of your OS, which can be found from :-
    http://us.blackberry.com/support/downloads/download_sites.jsp
    An app 205 error is a nasty error which is embedded in the software and has no work-around fix. Unless you fix this by reloading the OS, you'll basically need a whole new phone. Fortunately, reloading the OS has a very high success rate so I'm sure you'll get yours up and running in no time!!
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Jan 08, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
    I hate activesync, is it possible to reload the HTC phone OS?
    I've been told that smartphones are made for a certain OS and that OS only.
    Oct 07, 2009 | HTC P6500 WIN MOBILE 6 Smartphone
    How to reload windows mobile 5 on htc tynt?
    You need a specialised cable to reload Windows Mobile in the phone. Moreover its isnt publicly available and these cables and OS is given only to the authorised HTC service centers. Generally these cables are connected through the USB or the SIM card slot to the computer and a synchronising software in the computer is used to reload the OS.
    Mar 11, 2009 | HTC TyTN Smartphone
    Desktop screen
    hi
    if currently you r reloaded your os jenune verson then type product key when ask,other wise again reload os which is having cd key,other wise reload pirated verson os but it is risky for you .
    by by.
    Nov 19, 2007 | Acer Aspire 3680 Laptop
    Computers & Internet Logo
    21 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
