I removed the tape before inserting the cartridge. Still printing pink like the old cartridge did.I removed the tape before inserting the cartridge. Still printing pink like the old cartridge did.
You can't post conmments that contain an email address.
There is no way to reset the ink levels on this type of cartridge. As long as your printer still prints the cartridge is functioning properly. You should be able to check a box that says "ignore ink levels" when your computer pops up the box saying your cartridges are empty. Print until the ink runs out.
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate. Have some test on it at Printer Maintenance. I'm sure 100% works on it. Good luck!
Click
Start
or
, click All Programs
, click
Hewlett-Packard
, and then click
Printer Assistant
Click
Utilities
Click
View ink levels
If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
If the cartridges contain a sufficient amount of ink, continue to the next step.
Click
Printer Maintenance
Click
Clean Cartridges
Follow the on-screen instructions.
ISSUE:
After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level.
SOLUTION:
Continue
to print and ignore the ink level indicator. The print cartridge is
full of ink, it just is not being measured accurately.
You need to reset the ink level before the printer can print further, to do these please follow the following step: 1) Goto the Lexmark Solution Center application. 2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own. Then try again with printing alignment task. Hope this help.
