Question about Motorola Mobility RAZR V3m Cellular Phone
Ph will turn on but keypad won't work
When I turn on my phone I try to enter my security code, but none of the buttons are working on my keypad. I appreciate any advice you may have.Thanks for your time.
    Scholar:
  • 152 Answers
You need to replace your keypad. Frequent use deteriorates the interfacing connections.
Posted on Sep 13, 2008
My phone keypad is not working
Pavani Sharma, according to your explanation, there is two possibility of problem :1st hardware problem all keypad had a water damage that why it is not working you need to clean main board with alcohol and let it dry for 2 hours, if you don't know how to do it show some official repairer.2nd Software problem maybe your keypad is working properly without sim or with sim but is is freezing after some time. for this you need to do hard reset, for he hard rest first switch off device and then press and hold * 3 and green button and then power on wait until shows insert sim, if software problem persist then show some official repairer to fix for you.
Jul 16, 2012 | Nokia Classic 2700 Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
How to open nokia 7230 keypad security code
For 5 consecutive incorrect passcodes, you will be prompted that you have entered incorrect password 5 times and need to wait for couple of minutes. You really have to wait, after waiting you can enter the default code 12345 then it should be working fine then. If in case that this won't work, you can try to hard reset phone by entering *#7370# and you will need to select yes for restoring to factory defaults. Remember that it will delete the settings and data saved in the phone not on the memory card but it will still be advisable for you to have a back up of everything before doing so.
Sep 12, 2011 | Nokia 7230 Cell Phone
Hi How can I disable the auto keypad lock?
Just go to tools > settings > general > security > phone and simcard > keypad autolock period. then choose NONE, if ask for the code, enter your desire code or the default code will be 12345.
best regard,
Jun 25, 2011 | Nokia N8 Cell Phone
How do i change my code on my safe? it is a S-25E i have keys but want 2 change the code
Try this,
NOTE: The safe needs to be upright and right side up or the locking mechanism
won't work.
ELECTRONIC SAFES
To open an electronic safe the first time, press the following numbers/letters on the
electronic keypad -159B. (These numbers are preset. You should change the code as soon
as possible after opening the safe to insure proper security). After you have entered the
factory set code, you will need to turn the knob on the faceplate to open the door. You will
have 5 seconds to turn the knob before the locking mechanism is reactivated.
ENTERING YOUR SECURITY CODE
To enter your own security code you will need to follow the steps listed below:
1. After opening the electronic safe (with the pre -set factory code of 159B) locate the
small red button on the inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep.
DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW
SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits
long, and confirm your new code by pressing the letter "B" on the electronic touch pad.
Before you close the door, try the new security code to make sure the lock release the
knob so you can turn it and retract the live action locking bolts.
Good luck
Thanks
Apr 29, 2011 | Office Equipment & Supplies
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Forgot my keypad lock code and when i try to enter the master
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Sep 15, 2009 | Nokia 1600 Cellular Phone
Can't unlock keypad
The default security code for Nokia is 12345.
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Apr 03, 2008 | Nokia 6300 Cellular Phone
KRZR k1....
It sounds just like a keyboard lock and you need the code to unlock it. though it should be prompting you,
if you push * and # on the same time your keyboard locked. When you press it again, you unlock your keyboard
Your phone’s four-digit unlock code is
originally set to 1234
The six-digit security
code is originally set to 000000
If you forget your unlock code: At the
Enter Unlock Code prompt, try entering 1234 or the
last four digits of your phone number. If that
doesn’t work, press s and enter your
six-digit security code instead.
If you forget other codes: If you forget your
security code, SIM PIN code, PIN2 code, or
call barring password, contact your service
provider.
hope any of this helps .
Feb 02, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Keys will not work
Sounds like you locked the keypad.
I know you stated all the keys don't work, but let's give this a try.
Press the "unlock" key (the key in the upper left)
Enter your lock code (usually 0000)
Let me know if this helps.
Jan 11, 2008 | Sanyo MM-8300
Motorola Mobility RAZR V3m Cellular Phone Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
