My screen always goes white - Computers & Internet
  • 1 more comment
  • chickenwings Sep 13, 2008
    i might of droped my fone but other than that nothing. the screen jst goes white wen ever it wants but it comes back 2 normal after a while
    lol sounds like its time to get a new cell phone
  • Victor Castro
    Victor Castro May 11, 2010
    Can you describe any detail of any occurances before this happened, if you can maybe i can be of help. I specialized in LCD monitors.
  • 45 Answers
Well a white screen is not good. From your description it sounds like your FPD is about to die. The Display LCD panel begins to deteriorate or die after a prolong period of time. Due to the way they were assembled or used abusively(meaning not giving the LCD time to relax = aka turn off and cool).
NOt ALL do this, it all depends on use.
A possible solution would be to make sure all cables are fitted properly inside and out.
If you have working replacement parts, you might be able swap parts.
What is going to happen is --> its going to intermitten itself then finally when the bus(wire set) on the panel dies it will form an unviewable picture, possibly a nebula effect.
Posted on Sep 13, 2008
Nokkia 5130 -screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off...
nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Sep 22, 2011 | Nokia 5130 Cellular Phone
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
Nokia 5130: when I try to turn on the phone, the screen goes white and nokia logo appears like always, then the screen goes white and after several seconds it turns off
Try pulling the batter off of it and have someone test the battery for voltage and amperage. then try cleaning all the connectors and replace the battery. I had a phone that randomly dies and it was because the power connection was dirty.
Aug 05, 2010 | Nokia 5130 Cellular Phone
Random White screen On PB LCD 22inch
When the screen glows grey/white, it means that the T-CON board is bad or it is not getting the 5vdc from the logic board. or loose conection on the T-CON board which is part of the LCD panel assembly.
Does it look like this when it goes out? Checkto see if the 5vdc goes away when it goes out, the 5vdc is supplied through the switched transistor on the logic board..
Jul 02, 2010 | Soyo 19" LCD Flat Panel Monitor
Nokia 5130: blank screen, phone doesn't turn on
That means your phone got a corrupted software installed to its memory. A hard phone reset can solve this problem. Typically a nokia symbian series phone can be formatted using this code *#7370# then the default key is 12345.
Hope this could help.
Mar 26, 2010 | Nokia 5130 Cellular Phone
My phone always turns off. and the screen always turn white. but when it goes back to normal, the screen has no cracks. but after a couple of seconds, it turns white again
water damage. If you have a young child or dropped it on the bathroom floor after showering or even outside humidity can do that. Heat is also another thing that can do it. Or simply just dropping it.
Jun 13, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Acer aspire 4920 screen periodically goes white for seemingly no reason, and at random times. i've checked all of my drivers reinstalled vista and still it happens. after a clean install i didn't have a...
Well its not much of a solution but I have found a way to get on with it. I have set my monitor to turn off every minute unless am watching a movie oor something.
Once the screen goes white, I wait a minute then screen turns off and then I can use again.
Mar 29, 2009 | Computers & Internet
White screen
Generally an all white screen scenario is caused by no signal from the monitors video board getting to the actual screen.
It could be as simple as a disconnected ribbon cable that mounts the two items.
It could also be a fuse on the back of the actual lcd screens circuit board. These fuses are usually labeled F1.
If you have a tester and the capabilities, in normal running mode the screen should be getting around 5 volts dc at this fuse.
The other problem could be a bad video board. These are not always repairable.
Dec 13, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
