Question about Compaq CPQ/Presario5006EA uWave2 K7 Motherboard
Brand new laptop
When i turned on for the first time i didnt plug it in and the batt died and it didnt finish new startup now it wont finish installing windows
    Novelist:
  • 116 Answers
You're going to have to restart the install with your recovery disk. It probably didn't properly finish writing to the hard disk and is failing due to a read error on the file it was working on at the time.
Try using the disc and restarting the entire process. :)
Posted on Sep 13, 2008
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
Jan 25, 2014 | 2001 Dodge Stratus
1995 ford probe died when i turned on the a/c. sometimes it startssometimes it wont new timing belt,fuel pump filters,batt,plugs,cap rotor,wiresremitc@aol.com
Be careful your you A/C clutch maybe the problem it has a tendency to short out internally you should be able to see it and hear it dragging, also check the alternator and make sure it is charging.
May 17, 2011 | Ford Probe Cars & Trucks
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
My computer was working fine, but I lost my charger. I bought a universal charger and used it for some time. One day I plugged the computer in and the light on universal charger lit up until I plugged it...
I think that your battery is soooo flat it may be no good, take battery out, THEN connect the Correct adapter, and see if that works, if it does, then ya do need a new Batt, or perhaps a good long10-12 hour charge first, with NO use at all during that period.
Jan 26, 2010 | Toshiba Satellite M45X-S331 Notebook
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
1983 ford bronco 302 engine wont stay running after jumped
keep in mind, your engine use both source of power to run, one from the battery and one form alternator. If the alternator is good, your engine should stay running regardless if the battery is good or bad, the alternator should keep the engine running. It sound like to me the alternator is faulty not charging your battery or keeping your engine running, even though the alternator is brand new does not mean is good. My guess I would take the alternator back and get another one. the reason why your car ran for 25 min and die it has no source of power to keep the sparks going although the alternator should keep the engine running and at the same time charging the battery but is not.
Jul 12, 2009 | 1995 Chevrolet Caprice
I put my computer into hibernate, left for about 3 hrs and the battery died. when i got home i turned my laptop on, and the nvidia didnt look right. my desktop screen looks chunky and wide now, what do i...
Hi Enjoisays,
The issue here seems to be most likely a VGA cards issue. Since you had mentioned Laptop, and nivida, i presume it must be one of those notebooks from either toshiba, dell or acer (to my knowledge at least). If that is the case, it is also most liekly that the graphic cards is built into the motherboard and you must send it back for servicing.
The fact that your batt dies after 3 hours in hibernation also suggest that your priduct may be over a year old and that your batt lifespan is getting shorter. Some good practices when using a notebook is to use thr battery ONLY when on the road. If you're at home, try to use direct power via the charger provided. This will save the batt life for longer usage.
Oh yeah, and also, please note that chunky blots on screen with images not turning out right is def most of the time VGA issues. Hope this helped.
- Technomancer
Jun 09, 2008 | Compaq Computers & Internet
Compaq CPQ/Presario5006EA uWave2 K7 Motherboard Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
