Question about Whirlpool Washing Machines
Whrirlpool Front Loader Washing Machine AWO3561 - F11 Fault
I believe we have just had our Control Unit replaced on this machine. During our 1st load since this was replaced we experienced problems and by the thrid the F11 Fault including Flashing Start/Pause and some of the Spin Speed Buttons were flashing.
What are possible causes for the Control Unit to need to be replaced again after only 3 washes.
  • dbsh Sep 13, 2008
    Thanks. I had already done all of the above including contacting the Repair Man (who is going to order a new Control Unit on Monday. Maybe it is just a bad lot of CCU Boards. I originally posted this message because I was hoping there is something else wrong with the washing machine that is making the CCU board fail that also needs to be fixed.
Thanks for you help. I have now looked at your "Tips and Tricks" about the F11 error. I guess our repairer will carry out those checks as you have suggested. Sorry about not giving you feedback prior to rating. This rating was given purely because you didn't offer anymore answers than I had already done, in hindsight I did not provide you with all the information to allow you to make a more informed decision.
Posted on Sep 13, 2008
  • 5,911 Answers
Try unplugging the washer for at least 30 minutes before assuming you have a failed component. Sometimes you may experience a momentary glitch in the CCU. Unplugging the washer for this duration will often reset the error and return to normal operation. If the error code reappears, and it was just recently replaced, I strongly recommend getting in touch with the repair service you used. Most reputable companies guarantee their parts and labor against defects (some companies as much as 90 days). If this is a repeat failure, it may just be a bad lot of CCU boards and the company should replace it free of charge. I hope this helps you. Let me know if you require additional assistance.
  • Jeff Rockwell
    Jeff Rockwell Sep 13, 2008
    Thanks for Trying? I was hoping you provide me some feedback with these preliminary questions, first, so I could take the next step before you rated this. I had a link posted under the "Tips and Tricks" section of my proflie that explains the "F11" error in greater detail. Sorry that I could not help you any further,
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
How do you fix a fault F06 on a Whirlpool front loader washing machine
The "F06" fault code indicates a drive motor tachometer error. This means the control is unable to properly detect motor speed and the machine will shut down. If the failure occurs during high-speed spin, the door will unlock after 3 minutes. Possible Causes/Procedure: Unplug washer or disconnect the power supply. Check the wire harness connections between the motor and motor control unit and the harness connections between the motor control unit (MCU) and the Central Control Unit (CCU). Based on your symptom and details, the intermittent (F06) error code is likely a loose connection in the harness between the motor and the (MCU) or between the (MCU) and the (CCU). It could also be the tachometer circuit in the motor or an intermittent internal component connection within the (MCU). Since the (CCU) has already been replaced, the failure is likely a loose harness connection or the (MCU). I recommend calling the repair person back out to re-diagnose the failure. by Joey S MARCH 1ST, 2010 ' Be the first to comment
Jun 14, 2014 | Hotpoint Ultima WF860 Front Load Washer
My kenmore elite smartwash/he4t
The "F11" fault code will display if the Motor Control Unit (MCU) has an internal failure; repeating under or over voltage, or over current conditions. If failure occurs during high speed spin the door unlocks after 3 minutes. The MCU (Motor Control Unit) is located beside the motor. Here is the part to order.
Dec 02, 2012 | Kenmore Elite 45986 Front Load Washer
Washer code F11??? I have a Kenmore Elite front loader
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
Service manual and more HERE
Aug 22, 2011 | Kenmore Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Fault code F11 on whirlpool AWM8143 6th sense mwashing machine
got this from another site....
Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the motor control unit(MCU) and the central control unit(CCU).
A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves the parts changing monkey method: replace both boards,
But, on a brighter note, the electronics are covered under warranty for 24 months. If your machine is older that this, then you’ll need to shell out some shekels
tnx 4 using fixya,
drcool
Oct 05, 2008 | Whirlpool AWM8143 Front Load Washer
Front Load washer
FAULT CONDITION WHAT TO CHECK
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
A list of all fault codes for whirlpool duet; click on link. Hope this helps.
http://www.repair-help.com/kb/index.php?article=544
Jun 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
TROULBING SHOOTING FOR A FRONT LOADER KENMNORE ELITE 31T
check the screans on your water valves lf is a long fill Serial Communication Error
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check MCU
• Check CCU
• Check Motor
• Check Wire Harness thats the f11 error now if you pull the top off the washer you will find atech sheet in an envelope with troubleshotting procedures
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
When washing, it stops and says F11. What does that mean?
F-11=Serial Communication Error
Communication between the Central Control Unit( CCU)and the MotorC ontroUl nit
PotentialCauses
. CheckW ireH arnessc onnectiontso the MCU.t he motor,a ndC entraCl ontrol
Unit (CCU)
. Checkt he Drives ysteml or anyw orno r failedc omponents
. ReplaceM CU
. ReplaceC CU
. Replace Motor
. ReplaceW ireH arnes
Apr 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load - F11 Fault
I once had located a code combination to push on the control panel to clear the F11 code. I cannot locate that again. Can you please give me the combination to reset the machine?
Dec 16, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
