Question about Dishwashers
Miele dishwasher g664 12 years old maybe?
The dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose. I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
  • Lawrence6 Nov 26, 2008
    Miele dishwashers are made to last 20 years. This dishwasher is only just past the half way point.
    So much for Harvey your MASTER Plumber.
    The problem, (now fixed) was a little bit of fluf had blocked an outlet making the water overflow into the drip tray and tripping the overflow switch. Once the door cover had been removed I could see what the problem was. I gave the open track a good brush and pored a jug of water down it to make sure it was now clear and it was. Dishwasher will now last at least another eight years or MORE.
    So much for Harvey the Master Plumber who know nothing about Miele Dishwashers that are made to last at least 20 years. It is still better than most other dishwashers on the market, Hope this helps others.
    Novelist:
  • 171 Answers
Hi Lawrenceo,
I'm Harvey the Master Plumber.
You stated your problem as: the dishwasher won't drain.....can here a valve opening and gurgling but then no water exiting. Have cleaned everything and pushed water via tap back through water-exit hose.I to have a Miele G664 dishwasher and when turned on no water no fill. Just sits there with a moter running. Un able to get anyone to come and have a look at it as I live in Mount Victoria NSW.
It sounds like the pump has failed. The motor and the pump are two different parts. This is a common problem with older units. Frankly, after 12 years of use, at least you got your money's worth. At this age, to repair it is to throw good money after bad. It's time o replace it. You'll find there are much nicer models available now.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Hello, My dishwasher isn't draining the water away, it is approx 13 years old but not used to much in that time; Do you think I should buy a new one or get it fixed: it could be only a small problem: ...
On the whole dishwashers are simple devices.
A controller tells a pump what to do - push water around the machine or push water into the drain.
Miele machines have a very good record for lasting over 20 years.
If you are a "handy person" you could try checking the hose to the drain is clear - blocked hose won't drain.
Have you checked the filter system inside the machine - at the bottom of the d/washer under the bottom spinning arm? If this is blocked - no drain - so clean it well.
If little checks like this are all OK well its up to you - repairs could cost £60 - £80 a new Miele would be nearer £400.
Try to get it fixed its kinder to the planet - and your pocket.
Good Luck.
Mar 25, 2011 | Miele Premier-Plus Built-in Dishwasher
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
I have started hearing a gurgling sound in my diswasher air vent when I run water in my sink. Why has this begun happening? I have an /estate dishwasher Model TUD7000Y-0
Sounds like your waste water drains could be backing up and pushing water back into the dishwasher.
Firstly try pouring Mr Muscle sink and plughole un-blocker down the sink and leave overnight next morning pour boiling water down the sink and your pipes should be squeaky clean. Hopefully this will improve the flow and prevent gurgling!
Feb 21, 2009 | Miele 24 in. G870 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
if the water drains into a bucket then the blockage will be in the drain spigot under the sink where the drain hose connects.hope this helps.
Mar 14, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
Miele dishwasher
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance. Don't matter you could claim 100 times and never loose out. check it out! Also don't 4get to leave me feedback cheers raverbaby01
Aug 27, 2007 | Miele G880 Dishwasher
Dishwashers Logo
1,459 people viewed this question
Top Dishwashers Experts
