My DVD,CD,and ROM run faster than in should in audio it makes the voices go to fast what can I do to fix this problem?
  • luvourkids20 Sep 14, 2008
    I already fixed the problem it was simply the fact that my speed got changed in the computers settings and I didn't know how to fix it a friend of my came over tonight and fixed it for me in like 10 minutes. Thank you all anyway though.
    Problem Solver:
  • 5 Answers
Plug a set of headphones directly into the jack on the front of the drive (next to the little volume wheel) and play a music CD. If the sound is normal, the sound card drivers need to be reinstalled or updated. If not, the drive is shot, replace it, they're interchangeable and cheap.
Posted on Sep 13, 2008
My samsung dvd writer can't read cd
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area or if this fails to fix the problem
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Apr 23, 2011 | Samsung SH-S223C 22X DVD Writer SATA Black...
DVD/CD-ROM > Does not
your drivers may have been corrupted or you might have a virus run your antivrus program
make sure that the cd-dvd is getting enough power test all leads that are attached to the cd/dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 12, 2011 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
Disk drive not working
depending on which disc if its your hard drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 07, 2011 | Computers & Internet
It does not read any disk it shows blank.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
My cd-rom is not reconized by hard drive. it wont play or open the disk. Also ite not present on my computer icon when open
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
dont forget to vote
Feb 09, 2011 | Samsung SN 124 (SN-124) Internal 24x...
Not reading off a cd or dvd et
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area if this fails to fix the problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 07, 2011 | ASUS (DVDRWM3N) DVD Drive
Dvd audio
remove it from device manager and see whethrer there are any resource conflicts
May 24, 2010 | Creative Labs Sound Blaster Live! 5.1...
Nero burning on cd writer
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 08, 2008 | Compaq Presario 1200,1600 (297657-001)...
Dvd problem
not an easy one to fix,
first you'll need to find out if it's the lens adjustment or a laser problem. this will require you to open up the drive, and test it running open, use protective glasses to shield your eyes from the laser.
buying a new one is faster less time consuming and about 20 dollars. Removing it and connecting the new one, anyone can do 4 screws, and to diff cable that only fit one way.
Dec 06, 2007 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
