Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana Model ARS2667BW
Refrigerator stopped working couple of days ago. And today freezer seems to be acting funny. Can you help please with suggestions before I call a mechanic?
  • hellosutapa Sep 13, 2008
    Any idea how much it could cost in GA for a technician to repair?
    Sergeant:
  • 409 Answers
Sounds like the compressor or compressor relay. i would call a technician for this one.
Posted on Sep 13, 2008
  • Carmen Mikulic Sep 13, 2008
    not sure about GA but here in BC Canada, it costs about $80.00 to diagnose and if it's the compressor, i would check the warranty on it. most mfg. cover those from 5-10 years. get them to check that for sure.
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Our freezer just apparently stopped freezing, but the refrigerator still works. It's a Frigidaire Gallery just purchased a few months ago. Suggestions?
Hello, Thank You for using FixYa. I will be helping you today.All the cooling comes from the freezer side. So if the fresh food side is working then the freezer is only producing enough to allow the temps to be around 38 degrees. Do you notice any frost on the freezer back wall? Its possible its a defrost issue.Can you hear the fan Running in the freezer when the compressor is on? If these all seem fine then I would say you have a sealed system issue. Either a leak or bad compressor. Since its only a few months old call for factory service it should have a one year warranty on parts and labor.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hi, there! I have a WESTPOINT no Frost NF 120 and couple of days ago the fridge just stop working. The freezer is ok still working as usual, but the lower part is completly worm. The compressor is working,...
It's the Timer ..a device found on the left of the compressor at the back ..a few wires goes insinde. it has a watch gear mechanism..and a miniscule ant can stop it ..
May 14, 2011 | Refrigerators
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Apr 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
317 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
